[FOSS-GPS] High accuracy positioning with low cost
GPSdevices:aFOSS project
Tomoji Takasu
ttaka at yk.rim.or.jp
Mon May 18 05:08:31 EDT 2009
Hello, Stephan
> I ve sent you an RTCM-log from that WTZR0-station.
I checked your RTCM log of station WTZR0.
All of the type 1014 message header field "Synchronous GNSS
Flag" of WTZR0 are set to "1" as follows (sync=?).
1 decode_type1004:nsat=11 sync=1
3 decode_rtcm3: len=125 type=1012
3 decode_rtcm3: len=183 type=1004
3 decode_rtcm3: len= 64 type=1019
RTCM 3.0 or 3.1 defines "Synchronous GNSS Flag" as
"... If it is set to "1", it means that the next message will
contain observables of another GNSS source referenced
to the same Epoch Time."
RTKLIB recognizes that another observation data exists
with the flag and waits next data, but no next data comes
and it is discarded. In this case, "Synchronus GNSS Flag"
must be 0 to complete the processing of the epoch.
It might be due to the bug of the receiver or the server of
NRTK. So I do not provide the patch for RTKLIB 2.2.1.
If you want to avoid the problem. Please add the line:
sync=0;
after the line 473 of rtklib_2.2.1/src/rtcm.c and rebuild
RTKNAVI (and RTKPOST, RTKCONV).
Please refer the following "How to apply a patch" for the
build procedure.
http://gpspp.sakura.ne.jp/rtklib/rtklib_support.htm
Best Regards,
Tomoji TAKASU
----- Original Message -----
To: <foss-gps at lists.osgeo.org>
Sent: Monday, May 18, 2009 4:37 PM
Subject: Re: [FOSS-GPS] High accuracy positioning with low cost
> Hello ttakasu,
> this is a strange thing:
> Some RTCM3.0/3.1-Streams are processed correctly, for some, the Obs data
> are
> missing.
> Stefan
> http://n2.nabble.com/High-accuracy-positioning-with-low-cost-GPS-devices%3A-a-FOSS-project-tp1312818p2931210.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS
