[FOSS-GPS] RTKLIB: How to use it to develop a cheap DGPS basestation?
Tomoji Takasu ttaka at yk.rim.or.jp
Sat Nov 13 09:43:31 EST 2010
Dear Mauro
> I was trying to follow your code, looking for the step where the
> PseudoRange Correction and the Rate Range Correction (PRC[m] + RRC[m/s])
> are generated for each satellite (based on the raw data from the device
> used as base and the fixed position of it) before being feed to the
> solution computation for the rover position (when using DGPS mode), but I
> couldn't find it.
Current version (2.4.0) does not include RTCM output for
DGPS or RTK base station. Please use receiver raw
proprietary messages for this purpose at this moment.
I will add RTCM output function in the future version for raw
pseudorange and carrier-phase. I have not decided whether
to support RTCM 2 PRC-type DGPS correction for many
existing receivers. If many requests, I will consider it.
regards,
Tomoji TAKASU
WWW: http://gpspp.sakura.ne.jp
From: "Mauro Ugarte Avilés" <mauro.ugarte at cefop.udec.cl>
Sent: Friday, November 12, 2010 5:17 AM
To: <foss-gps at lists.osgeo.org>
Subject: [FOSS-GPS] RTKLIB: How to use it to develop a cheap DGPS
basestation?
> Dear Tomoji,
> DGPS base stations are much more expensive than some well known receivers
> that can output raw data, and considering that RTKLIB can use that data
> and correct the pseudoranges of a rover, I was thinking if it is possible
> to use those corrections to output them as RTCM SC-104 messages, thus
> developing a cheap DGPS base station using, for example, some decent
> antenna, an u-blox 5T and RTKLIB with some addition.
> couldn't find it.
> Can you please give me some advice at where to look on RTKLIB code for
> that computation step? Any other suggestion, tip or comment about what I'm
> trying to do will be more than welcome.
> Best regards to you and all list members,
> Mauro Ugarte A.
> PS.: For those of you wondering why do I want to use DGPS in the first
> place, is because here in Chile there is nothing like WAAS, and I need to
> increase accuracy on pedestrian rovers on rural areas, where the ammount
> and quality of the data required for RTK are unachievable with small GPS
> antennas and variable RF links.
>   Este correo electrónico y  cualquier archivo adjunto son confidenciales
> y son solamente para el uso del individuo o entidad a la que van
> dirigidos.
> Si ha  recibido  este correo  electrónico por error por favor notifique al
> remitente.  Este  mensaje contiene  información confidencial dirigida a la
> persona  implicada.  Si  usted  no  es  esa  persona  no debiera
> diseminar,
> distribuir o copiar este mensaje de correo electrónico.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
