[FOSS-GPS] rtklib: antenna models and how to create them
Tomoji TAKASU ttaka at yk.rim.or.jp
Mon Nov 22 18:33:53 EST 2010
Dear Timo
Thanks Thomas for helpful comment.
In addition to Thomas's comment, I had measured several cheap
antenna's PCV 2 yeas ago. Refer the following page and paper.
http://gpspp.sakura.ne.jp/anteva/antpcv.htm
http://gpspp.sakura.ne.jp/paper2005/isgps2008_paper_ttaka.pdf
Usually the consumer-grade antenna's PCV model is not provided.
So you have to measure it by yourself. If you do not care cm-level
accuracy, you need not to apply PCV model to your antenna.
regards,
Tomoji TAKASU
WWW: http://gpspp.sakura.ne.jp
-----Original Message-----
Sent: Tuesday, November 23, 2010 1:59 AM
To: Open Source GPS-related discussion and support
Cc: Tomoji TAKASU
Subject: [FOSS-GPS] rtklib: antenna models and how to create them
Hello Tomoji,
rtklib-2.4.0/data/ngs_abs.pcv seems to contain antenna models for 229
different antennas. Were these imported from some public database?
Is there some procedure that I could follow to create an antenna model
for my extremely cheap antenna?
best regards,
Timo Lindfors
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 9.0.869 / Virus Database: 271.1.1/3269 - Release Date: 11/21/10
04:34:00
More information about the FOSS-GPS mailing list
