[FOSS-GPS] rtklib: Initial setup
Timo Juhani Lindfors timo.lindfors at iki.fi
Mon Nov 29 11:29:50 EST 2010
Degerman Pär <par.degerman at scania.com> writes:
> I see, I tinkered around in u-Center and found the setting. The data/ubx_raw_1hz.cmd file actually does not specify anything other than the update speed (1Hz). File was taken from rtklib_2.4.0_bin.zip. Should that be changed? I can probably provide a patch.
Aha indeed, you are right. Maybe rtklib could ship a file that puts
the device to UBX mode?
More information about the FOSS-GPS mailing list
