[FOSS-GPS] foxtrotgps map detail option (was: Questions about foxtrotgps)
James Hiebert james at hiebert.name
Wed Oct 13 00:52:32 EDT 2010
> Yes, it's in gconf as /apps/foxtrotgps/global_detail_zoom, though
> gconf is currently queried only at startup--so you can't induce changes
> in a running instance of foxtrotgps by `sneaking in the back door'
> and twiddling gconf parameters.
Thanks; that helped me reset the option back to the default.
> But my guess as to why you're not seeing the details shrink would be
> that you don't have actually have the higher-detail tiles: if you zoom in
> to level 10, for example, but have tiles only up to level 9, then it'll
> `overzoom'--the idea being that a less-detailed or blurry section
> on the map is better than an *empty* section.
No, that's not the case.  This is in the city where I live, where I
regularly contribute to OSM, and have all the tiles downloaded to zoom level
16.  foxtrot was definitely _not_ showing the highest level detail
available.  But it's OK...  now knowing how to twiddle the setting with
gconf offline, I can still maintain functionality while playing with the
option to get a better description for a bug report (if applicable).
~James
On Wed, Oct 13, 2010 at 12:29:33AM -0400, Joshua Judson Rosen wrote:
> James Hiebert <james at hiebert.name> writes:
> > I think that the "map detail" option in the map context menu is broken.
> > I clicked the "map detail->fewer/larger details" option at one point.
> > However now the map is stuck there.  If I click the "map detail->
> > more smaller details" option I get no change.  Is there some
> > place that exposes this option elsewhere (maybe through gconf, on
> > which I'm no expert)?
> "Don't be afraid to ask (λf.((λx.xx) (λr.f(rr))))."
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
