[FOSS-GPS] FoxtrotGPS bug-tracker
Joshua Judson Rosen rozzin at geekspace.com
Tue Oct 19 01:51:00 EDT 2010
Brian Wilson <brian at wildsong.biz> writes:
> > I should probably add a link to it from the FAQ....
> Bad move, people will actually start to use it if you do that. It's so
> empty right now!
> I will only enter things that I am about to fix. It will be like the
> FBI Most Wanted list that way. Make everyone look good.
No, by all means--file bugs even if you're not prepared to fix them
yourself; someone else might then find them, help fix them, and
save you the effort :)
Anyway, there are now links to the BTS on the website:
    http://www.foxtrotgps.org/
"Don't be afraid to ask (λf.((λx.xx) (λr.f(rr))))."
More information about the FOSS-GPS mailing list
