[FOSS-GPS] Position modes in RTKPOST
Tomoji TAKASU ttaka at yk.rim.or.jp
Tue Nov 1 10:51:02 EDT 2011
Dear Antonio
> 2. By EKF are you referring to "extended Kalman filter"? I suppose that
> "extended Kalman filter" is KF applied to non-linear mathematical models.
> Am I right?
Yes.
If either the system-model or the measurement-model
is non-linear, "extended" KF is used. In the RTKLIB case,
only the measurement-model is nonlinear. The system-
model is not nonlinear.
Someone use it only for a non-linear system-model. If
so, RTKLIB just employs KF.
regards,
Tomoji TAKASU
From: "António Pestana" <afsm.pestana at gmail.com>
Sent: Tuesday, November 01, 2011 10:38 PM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] Position modes in RTKPOST
> Dear Mr. Takasu
> Once again I must thank you for your patience and kindness.
> Regarding your answer to my questions:
> 1. Yes, you are right: I mean "least square".
> Am I right?
> Best regards
> Antonio
>>  I think that a) and b) are not suitable to RTK positioning because of
>> the
>>> ill-conditioning of the design matrix (very short observation time
>>> spans,
>>> frequently one solution per epoch). I'm I right?
>> Not right.
>> KF can handle only one epoch observations
>> (but usually has no meaning). LS or KF is just
>> a design selection.
> 1. RTKPOST "static" is like c.1)?
>>> 2. RTKPOST "kinematic" is like c.2) or c.3)?
>>> 3. And RTKPOST "single"? Is it LMS/WLMS?
>> In "single", RTKPOST uses weighted LS.
>> In other modes, RTKPOST uses EKF.
>> regards,
>> Tomoji TAKASU
>> Sent: Tuesday, November 01, 2011 6:48 AM
>> To: "Open Source GPS-related discussion and support" <
>>  Dear Mr. Takasu an other list members:
>>> I am aware (not really aware, I've just heard off...) of the following
>>> solutions to the positioning problem we are dealing with (GNSS
>>> positioning):
>>> a) Least mean square (LMS)
>>> b) Weighted least mean square (WLMS)
>>> c) Kalman filter
>>> c.1) static positioning: coordinates of the receiver are constants and
>>> the
>>> estimated clock offset of the receiver is white noise with zero mean
>>> c.2) kinematic positioning for high receiver velocity: coordinates and
>>> clock offset are modelled as zero mean white noise
>>> c.3) kinematic positioning for low velocity: the coordinates are
>>> modelled
>>> as a random walk
>>> the
>>> spans,
>>> If I'm right then it follows that in RTK we are using some sort of
>>> "Kalman
>>> filter" type solutions. And if we are using "Kalman filters" type
>>> solutions
>>> then the following questions arise:
>>> Regards
>>> Antonio
>>> 2011/10/28 Tomoji TAKASU <ttaka at yk.rim.or.jp>
>>>  Dear Antonio
>>>>  Can anyone explain give me a brief explanation regarding the
>>>> differences
>>>>> between the position modes options in RTKPOST? I am especially
>>>>> interested
>>>>> in
>>>>> the following modes: Single, Kinematic, Static, Moving-base and Fixed.
>>>> I think they are generally common terminologies
>>>> among GNSS positioning area except for "Fixed".
>>>> So see the manual and search by Google.
>>>> "Fixed" is special in RTKLIB. In the mode, the user
>>>> position is fixed to a priori values specified by user
>>>> options and other parameters like ionosphere,
>>>> troposphere are estimated. It is also used for the
>>>> analysis of measurement noise and multi-path with
>>>> residuals.
>>>> regards,
>>>> Tomoji TAKASU
>>>> Sent: Saturday, October 29, 2011 3:34 AM
>>>> Subject: [FOSS-GPS] Position modes in RTKPOST
>>>> differences
>>>>> interested
>>>>> in
>>>>> Regards
>>>>> Antonio
>>>>  ______________________________****_________________
>>>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing
>>>>> list.
>>>>> Visit
>>>>> http://lists.osgeo.org/****mailman/listinfo/foss-gps<http://lists.osgeo.org/**mailman/listinfo/foss-gps>
>>>>> <http**://lists.osgeo.org/mailman/**listinfo/foss-gps<http://lists.osgeo.org/mailman/listinfo/foss-gps>>to
>>>>> manage your subscription
>>>>> For more information, check
>>>>> http://wiki.osgeo.org/wiki/****FOSS-GPS<http://wiki.osgeo.org/wiki/**FOSS-GPS>
>>>>> <http://wiki.osgeo.**org/wiki/FOSS-GPS<http://wiki.osgeo.org/wiki/FOSS-GPS>
>>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>>> Visit
>>  ______________________________**_________________
>>> Visit
>>> http://lists.osgeo.org/**mailman/listinfo/foss-gps<http://lists.osgeo.org/mailman/listinfo/foss-gps>to
>>> http://wiki.osgeo.org/wiki/**FOSS-GPS<http://wiki.osgeo.org/wiki/FOSS-GPS>
>> Visit
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
