[FOSS-GPS] RTKLIB SKYTRAQ
Fred Labrosse ffl at aber.ac.uk
Wed Aug 22 07:21:03 PDT 2012
On Saturday 18 August 2012 20:04:43 julio menezes wrote:
> Hi Fred
> --- Em qui, 16/8/12, flabrosse <ffl at aber.ac.uk> escreveu:
> > De: flabrosse <ffl at aber.ac.uk>
> > Assunto: Re: [FOSS-GPS] RTKLIB SKYTRAQ
> > Para: foss-gps at lists.osgeo.org
> > Data: Quinta-feira, 16 de Agosto de 2012, 12:59
> > Hi all,
> > I am facing that exact same problem.  My 2 skytraq
> > receivers only give me a
> > position described as SINGLE, with a standard deviation of
> > the position of
> > about 6-7 metres, nothing better.
> > Have other people solved that problem?
> > Cheers,
> > Fred
> Could you make your data available, raw / RINEX, and configuration files
> that you are using for ? Maybe it will help someone to find and fix the
> problem.
I think my problem is solved (or close to it anyway).  I emailed the support
address of RTKLIB and got a few emails back.
The problem is that the position of the base station has to be given.  I
thought that if I only wanted a relative position I didn't need to, but it
appears that I have to.  I just gave a rough estimate of the position of the
base station and now easily get a FLOAT solution, sometimes a FIX.  Next step
is to post-process base station log files to hopefully get a better position
for it, and therefore a better kinematic solution.
Will report back.
Cheers,
Fred
> best regards,
> julio menezes
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription For more information, check
> http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
