[FOSS-GPS] Kinematic vs PPP Kinematic?
Danny Miller dannym at austin.rr.com
Tue Aug 28 02:49:16 PDT 2012
Well, now, I've seen the LEA-6P units are standalone PPP.  But RTKLib
has kinematic mode which seems to use 2 units and this "differential".
I did download the patched version of rtknavi that has a PPP fix.
I discovered that the PPP "Static" for determining the base station
location was pretty stable- however, it determines the location for the
"rover" only, so I just swapped the rover and base port #'s to determine
the static base location.
When I selected PPP Kinematic, the fix jumps several meters back and
forth rapidly, but never seemed to stabilize much, and the noise wasn't
really centered on the true location either.
I ordered the NV08C-CSM units, BTW.  These new kids on the block are GPS
AND GLONASS,  Galileo, Compass, and SBAS, 2.5m standard accuracy, and a
few months back the mfg released firmware to expose the RAW pseudorange
data.  Michele Bavaro thinks highly of them, and there's a hacked
version of RTKLib for them:
http://michelebavaro.blogspot.com/
So, this should be fun!
Danny
On 8/28/2012 3:49 AM, Michele Bavaro wrote:
> There is a huge difference actually.
> The first is differential, the second standalone.
> Cheers,
> Michele
> On 28/08/2012 09:39, Danny Miller wrote:
>> Could someone explain the difference between simple Kinematic and PPP
>> Kinematic in RTKLib?
>> Danny
>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>> subscription
>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20120828/301d934c/attachment.html>
More information about the FOSS-GPS mailing list
