[FOSS-GPS] rtklib ( no base station observation data for rtk )
Willem Dantuma wjdantuma at gmail.com
Wed May 9 08:29:02 EDT 2012
Hi Mauro,
Yes i enabled RAW protocol mode and the RXM-RAW and RXM-SFRB messages on
both receivers.
Best regards,
Willem
On Tue, May 8, 2012 at 6:55 PM, Mauro Ugarte Avilés <
mauro.ugarte at cefop.udec.cl> wrote:
>  Hi Willem, did you set up the output of RXM-RAW messages on both
> receivers and RXM-SFRB message on one of them (preferably on the receiver
> connected to the PC running rtknavi, to reduce the data transfer load
> managed by tcpsrv-tcpclient)?. You also need to set the "RAW" protocol mode
> on the ports used to output those messages in both receivers.
URL: http://lists.osgeo.org/pipermail/foss-gps/attachments/20120509/da11f35c/attachment.html
More information about the FOSS-GPS mailing list
