[FOSS-GPS] UCenter enable RXM-RAW packets
Timo Juhani Lindfors timo.lindfors at iki.fi
Fri Mar 1 00:45:11 PST 2013
Michele Bavaro <mic.bavaro at yahoo.co.uk> writes:
> Well I did not know of a RAM hack, assuming that the antaris4 trick
> does not work on LEA6H.
> The modification I have seen is a flash update, so sticks after a
> power cycle.
Aha, can you give a pointer to that for evaluation purposes only(TM)?
More information about the FOSS-GPS mailing list
