[FOSS-GPS] Decoding UBX data
Tomoji TAKASU ttaka at yk.rim.or.jp
Thu Mar 14 15:39:05 PDT 2013
Dear Par,
Thanks for pointing out a problem.
> I managed to get a version of that code running, but
> I had to change one file of rtklib to make that happen.
> The change needed was that I commented out the
> free_raw on line 300 of rcwraw.c. The free_raw calls
> free() on the members of the struct. Then the struct
> members are again accessed which causes a
> segmentation fault on my platform.
Or you can also initialize the raw struct in advance
(without modification of RTKLIB).
raw_t raw;
raw_t raw={0};
regards,
Tomoji TAKASU
Sent: Thursday, March 14, 2013 4:50 PM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] Decoding UBX data
> Dear Tomoji,
>> Like the following codes.
> I managed to get a version of that code running, but I had to change one
> file of rtklib to make that happen. The change needed was that I commented
> out the free_raw on line 300 of rcwraw.c. The free_raw calls free() on the
> members of the struct. Then the struct members are again accessed which
> causes a segmentation fault on my platform.
> I'm using visual studio 2008 32 bit on a 64 bit platform and compiling in
> debug mode. I'm not sure if I have introduced a memory leak making this
> change or any other errors, but for my current use case this solution
> seems to work.
> Best regards
> - Pär
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
