[FOSS-GPS] impressed
napoleon vroumanis at gmail.com
Sat Mar 16 01:04:42 PDT 2013
Hello,
My setup is:
Rover:40db tallysman antenna, lea-4t receiver
Base: leica 1202gg antenna ntrip caster connection,rtcm 3 data.
baseline 6.68 m
base -kinimatic solution
I searched for the lea-4t configuration, i set it up, i pressed ''start''and
i had first fix after 1.5 minute and stable fix after 7 minutes....(less
than 2.5cm)-MY FIRST TRY
Looks like a joke.
I am totally impressed.
I am planning a new config with tallysman gnss antenna and nvs-08 and i am
afraid to imagine the result.
I will also test vrs and max solutions from the base network (i guess i can
feed max solution through rtcm 3 to rtklib)
Anyway i have to say again that i am impressed and to thank you ttakasu and
team.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/impressed-tp7572660.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
