[FOSS-GPS] impressed
Tomoji TAKASU ttaka at yk.rim.or.jp
Tue Mar 19 01:24:38 PDT 2013
Dear oddpost
2.4.2b11 does not support mount-points containing "/".
The problem will be fixed in the formal 2.4.2 released
at the end of this month. Please wait for a while.
Tomoji TAKASU
Sent: Tuesday, March 19, 2013 5:04 PM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] impressed
> Dear Tomoji,
> thanks a lot for your help and very quick reply. I very appreciate your
> comments.
> Could you please also let me know whether ntrip mount point can have slash
> in its name? ("/")
> As an example:
> Mountpoint:
> Test/RTK
> Ntrip Browser shows mount points successfully ("Test/RTK"), but  after
> that in ntrip client options part of the mount point name goes to Port
> field (81/Test).
> And of course after that no mountp error occurs.
> Please check screenshot for your reference.
> Thanks a lot!
> On Mar 19, 2013, at 3:37 PM, "Tomoji TAKASU" <ttaka at yk.rim.or.jp> wrote:
>> Dear oddpost
>>> When working with Type 18 and Type 19 messages, should Input
>>> Stream be set as (2) Base Station or (3) Correction?
>> Please set (2).
>>> Options for positioning mode should be set as "Kinematic"?
>> If moving, set "Kinematic".
>> If stationary, set either "Kinematic" or "Static".
>> Tomoji TAKASU
>> From: "oddpost" <oddpost at ya.ru>
>> Sent: Tuesday, March 19, 2013 4:22 PM
>>> Hello,
>>> I am trying to figure out rtknavi settings. I am using openmoko
>>> freerunner and would like to get relatively precise positioning (using
>>> RTK).
>>> I have access to ntrip, providing Type 1 (differential GPS corrections),
>>> Type 3 (BS parameters), Type 18 (uncorrected carrier phase
>>> measurements),
>>> Type 19 (virtual distance uncorrected observations).
>>> When working with Type 18 and Type 19 messages, should Input Stream be
>>> The idea is to get the following simple architecture:
>>> freerunner --> rtknavi <---- ntrip
>>> Thanks a lot for your help
>>> On Mar 16, 2013, at 11:46 PM, Artyom G <gnsssdr at gmail.com> wrote:
>>>> Dear all,
>>>> I also want to thank developers of RTKlib.
>>>> During last month one the students under my control tested nvs08c-csm
>>>> with
>>>> RTKlib. At first we tried to get our coordinates relative to RTCM base
>>>> station. During 3 days the difference in fix-position coordinates
>>>> didn't
>>>> exceed 1cm (on each coordinate). Distance between RTCM station and our
>>>> antenna was about 3 km. Then we determined coordinates between RTCM
>>>> station
>>>> and second reciever. And at the end we determined coordinates between
>>>> two
>>>> nvs08c-csm receivers (baseline about 8m).
>>>> We also checked manually baseline distance between two nvs08c-csm
>>>> receivers
>>>> by subtracting coordinates of the first nvs08c-csm receiver (that were
>>>> got
>>>> relative to RTCM station) from the coordinates of the second nvc08c-csm
>>>> receiver (that were also got relative to RTCM station). The result was
>>>> the
>>>> same as RTKlib outputed.
>>>> I also appreciated strongly the posibility to stream data from receiver
>>>> through "strsvr". It was very comfortable to work with receivers output
>>>> in
>>>> parallel with the student.
>>>> Thanks a lot for RTKlib.
>>>> On Sat, Mar 16, 2013 at 1:40 PM, Michele Bavaro
>>>> <mic.bavaro at yahoo.co.uk>wrote:
>>>>> Great, thank you!
>>>>> Too many times we hear the opposite.
>>>>> I am glad that - for once - someone has been willing to share his good
>>>>> results with RTKLIB combined with low cost receivers.
>>>>> To cool down you enthusiasm a bit, I anticipate that you should not
>>>>> expect
>>>>> much difference between a LEA-4T and a NV08C-CSM. Carrier phase noise
>>>>> is
>>>>> similar and despite tracking Glonass, that is still hardly usable by
>>>>> RTKLIB
>>>>> since it is affected by the well-known biases any Glonass receiver RF
>>>>> receive path is subject to. And RTKLIB "auto-calibration" feature is
>>>>> still
>>>>> not implemented.
>>>>> If I am allowed, I am under the impression that Tomoji's development
>>>>> road-map is adding more and more features to RTKLIB so that now
>>>>> resembles
>>>>> very much a professional product rather than an open-source
>>>>> *one-man*effort. Surely having multiple frequencies, multiple
>>>>> constellations, super
>>>>> standalone post-processing (PPP), and beautifully coloured GUIs is
>>>>> great
>>>>> and we are always grateful to him for that. But I wonder how many
>>>>> users
>>>>> desire to have a robust and very lean single frequency GPS RTK
>>>>> algortihm.
>>>>> One that can run headless on Android perhaps, or even on a STM32F4
>>>>> bare
>>>>> metal. One that can fill the gap with the most common quirks of
>>>>> low-cost
>>>>> receivers (e.g. random phase slips) and use some sort of
>>>>> pre-processing
>>>>> RAIM to indentify and exclude outliers. One that can be integrated in
>>>>> robotic automatic guidance projects.
>>>>> Back to receivers, the only real difference between NV08C-CSM and
>>>>> LEA-4T
>>>>> is that the latter is gone out of production several years ago, and
>>>>> uBlox
>>>>> has not replaced it with an equally performing module. 5T and 6T in
>>>>> fact
>>>>> can only measure at 10Hz under certain conditions and they are not
>>>>> certified to do that anyway.
>>>>> So if you need a module to build a commercial product you only have
>>>>> three
>>>>> choices right now: NVS NV08C-CSM, ublox 6T/P, and Skytraq S1315F-RAW.
>>>>> Of the three, only the first has to my knowledge a clear development
>>>>> and
>>>>> upgrade path. There are rumors that the new revision of NV08C -to come
>>>>> out
>>>>> later this year- will fully support Galileo and, as most of us know,
>>>>> Galileo Signal In Space specifications guarantee interoperability with
>>>>> GPS
>>>>> by design. Thus, as soon as there will be a sensible number of Galileo
>>>>> birds in the sky, dual constellation low-cost RTK will become easily
>>>>> useable by all of us. Not to mention dual frequency of course, as L5
>>>>> and
>>>>> E5a bands overlap.
>>>>> Congratulations again and keep it up,
>>>>> Michele
>>>>> On 16/03/2013 09:04, napoleon wrote:
>>>>> Hello,
>>>>> My setup is:
>>>>> Rover:40db tallysman antenna, lea-4t receiver
>>>>> Base: leica 1202gg antenna ntrip caster connection,rtcm 3 data.
>>>>> baseline 6.68 m
>>>>> base -kinimatic solution
>>>>> I searched for the lea-4t configuration, i set it up, i pressed
>>>>> ''start''and
>>>>> i had first fix after 1.5 minute and stable fix after 7
>>>>> minutes....(less
>>>>> than 2.5cm)-MY FIRST TRY
>>>>> Looks like a joke.
>>>>> I am totally impressed.
>>>>> I am planning a new config with tallysman gnss antenna and nvs-08 and
>>>>> i am
>>>>> afraid to imagine the result.
>>>>> I will also test vrs and max solutions from the base network (i guess
>>>>> i can
>>>>> feed max solution through rtcm 3 to rtklib)
>>>>> Anyway i have to say again that i am impressed and to thank you
>>>>> ttakasu and
>>>>> team.
>>>>> View this message in context:
>>>>> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/impressed-tp7572660.html
>>>>> Sent from the Open Source GPS-related discussion and support mailing
>>>>> list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing
>>>>> list.
>>>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>>>>> subscription
>>>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>>>>> list.
>>>>> subscription
>>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>>> subscription
>>> subscription
>> subscription
> Dear Tomoji,
> comments.
> in its name? ("/")
> As an example:
> Mountpoint:
> Test/RTK
> field (81/Test).
> Thanks a lot!
>  Dear oddpost
>  Please set (2).
>  Tomoji TAKASU
>    Hello,
> RTK).
> corrections), Type 3 (BS parameters), Type 18 (uncorrected carrier phase
> measurements),
>      Dear all,
> with
> base
> didn't
> our
> station
> two
> receivers
> were got
> nvc08c-csm
> was the
> receiver
> output in
>        Great, thank you!
> good
> expect
> noise is
> by RTKLIB
> RF
> is still
>        not implemented.
> development
> resembles
> great
> users
> algortihm.
> bare
> low-cost
> pre-processing
> in
> LEA-4T
> uBlox
> fact
> three
> S1315F-RAW.
> development and
> come out
> know,
> with GPS
> Galileo
> easily
> L5 and
>        E5a bands overlap.
>        Michele
>        Hello,
>        My setup is:
>        baseline 6.68 m
> ''start''and
> minutes....(less
>        Looks like a joke.
> and i am
> guess i can
> ttakasu and
>        team.
> mailing list archive at Nabble.com.
> list.
> your subscription
> list.
> your
>        subscription
> list.
> subscription
> subscription
> subscription
> subscription
More information about the FOSS-GPS mailing list
