[FOSS-GPS] Raw Data from NEO-6M
Scott Harrison scott at sharrison.net
Thu Jun 12 05:44:29 PDT 2014
seabass,
There seem to be several examples for Arduino online.  Here is a better one.
On Thu, Jun 12, 2014 at 8:25 AM, Scott Harrison <scott at sharrison.net> wrote:
> seabass,
> Yes you can. In fact I did a little work on a similar problem a short
> while ago but I am traveling now and haven't got back to it.  In my case, I
> was writing a desktop app to configure the uBlox module in linux via a
> serial connection (or FTDI usb to serial).  I don't use Windows much and
> was getting tired of switching operating systems to run uBlox.  I have
> attached a small Arduino Project sample file I found on Saintsmart earlier.
>  You should be able to get the example running with a few tweaks.
> Good luck.
> On Thu, Jun 12, 2014 at 1:55 AM, seabass <seabasscropper at gmail.com> wrote:
>> Scott,
>> I have been playing around with a Ublox Neo 6m receiver, and i have been
>> using the UbloxRaw codes to enable Raw and SFRB messages.
>> I'm wondering if anyone has got these codes working outside of U-Centre,
>> do
>> you think it is possible to send these messages via Arduino?
>> View this message in context:
>> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Raw-Data-from-NEO-6M-tp7572786p7572920.html
>> Sent from the Open Source GPS-related discussion and support mailing list
>> archive at Nabble.com.
>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>> subscription
>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140612/855576f6/attachment-0001.html>
Type: text/x-arduino
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140612/855576f6/attachment-0001.bin>
More information about the FOSS-GPS mailing list
