[FOSS-GPS] Good antenna
Anton Strydom agstrydom at gmail.com
Mon Mar 10 23:10:41 PDT 2014
Hi Max
Have a look at the attached, this is what I started off using it with a
U-Blox 6 T receiver
Regards
Anton
On Tue, Mar 11, 2014 at 7:52 AM, mazahirp <mazahir.poonawalla at gmail.com>wrote:
> Hi All,
> Can anyone help me to buy a good antenna which can give me accurate
> results.
> I am using u-blox 6T as receiver and RTKLIB.
> Currently I am using GILSON GPS active antenna on both the receivers (base
> and rover). I am not an expert into antennas so I wanted to know if this
> antenna is good enough? If not, which one should I go for. My budget is
> around $100.
> Thanks for the help.
> Cheers,
> Max
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Good-antenna-tp7572830.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140311/7dba743f/attachment-0001.html>
Name: GPS Helical Antenna Design.pdf
Type: application/pdf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140311/7dba743f/attachment-0001.pdf>
More information about the FOSS-GPS mailing list
