[FOSS-GPS] Mobile Robot Experimentation
Sean Hyde sean.a.hyde at gmail.com
Wed Sep 17 19:01:09 PDT 2014
Hello Felipe,
What do you mean by “process base versus CORS”?  Do you mean running rtknavi with the CORS as an input?
The Rover was operating within 30m of the base, but I can try it closer if that would help.
On the next test, I will let the Rover idle for a while before starting the test.  The antenna (or rather the steel plate) is the highest point on the robot (by about 30cm).  The base, however is rather low to the ground and I am trying to build something to elevate it more.
-Sean
From: foss-gps-bounces at lists.osgeo.org [mailto:foss-gps-bounces at lists.osgeo.org] On Behalf Of Felipe G. Nievinski
Sent: Wednesday, September 17, 2014 9:50 PM
To: foss-gps at lists.osgeo.org
Subject: Re: [FOSS-GPS] Mobile Robot Experimentation
before anything else, check what accuracy you get
with the rover parked for a couple of hours.
to isolate which one between rover and base
is noisier, download data from the nearby CORS,
then process your base versus CORS and your rover
versus CORS separately.
keep your base as close as possible to the rover.
that's the best way to mitigate iono delay
without dual-frequency tracking data.
turn on the GPS on the rover for some time
before it departs, as it should help with
ambiguity resolution.
try to elevate the antenna above the body
of the robot, so as to minimize multipath
and EM interference.
On Wed, Sep 17, 2014 at 6:06 PM, <foss-gps-request at lists.osgeo.org <mailto:foss-gps-request at lists.osgeo.org> > wrote:
Send FOSS-GPS mailing list submissions to
        foss-gps at lists.osgeo.org <mailto:foss-gps at lists.osgeo.org>
To subscribe or unsubscribe via the World Wide Web, visit
        http://lists.osgeo.org/mailman/listinfo/foss-gps
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        foss-gps-owner at lists.osgeo.org <mailto:foss-gps-owner at lists.osgeo.org>
When replying, please edit your Subject line so it is more specific
than "Re: Contents of FOSS-GPS digest..."
Today's Topics:
   1. Mobile Robot Experimentation (Sean Hyde)
Message: 1
Date: Wed, 17 Sep 2014 17:05:35 -0400
From: "Sean Hyde" <sean.a.hyde at gmail.com <mailto:sean.a.hyde at gmail.com> >
To: <foss-gps at lists.osgeo.org <mailto:foss-gps at lists.osgeo.org> >
Subject: [FOSS-GPS] Mobile Robot Experimentation
Message-ID: <0ddc01cfd2bb$20551d40$60ff57c0$@gmail.com <http://gmail.com> >
Content-Type: text/plain; charset="us-ascii"
Hey Guys,
I've been playing around with RTKLib for a couple months now and have run
into some issues and I was wondering if anyone had any idea on how to
improve performance.
---Setup---
Base Station:
NVS08C on custom PCB using the receiver to power the antenna
Antenna is Taoglas Limited AA.161.301111
(http://www.taoglas.com/images/product_images/original_images/AA.161.301111. <http://www.taoglas.com/images/product_images/original_images/AA.161.301111.pdf>
pdf)
Antenna is on a 12" x 24" steel plate
Connected via FTDI->USB to Rasperry Pi
Raspberry Pi runs str2str to send the data to Windows laptop running rtknavi
using wifi backhaul
Rover:
pdf)
Antenna is on a 18" x 18" steel plate
using wifi backhaul
The Rover setup is on a small mobile robot with a top speed of about 3mph.
It is in a city (Pittsburgh), but the sky is relatively unobstructed.
I'm running rtknavi in Kinematic mode using only GPS, L1+L2, 15deg elevation
mask.  The position that I input for the base station is a 5 hour average
(though it seems to have lost some precision when I pasted it?).  I have
tried both Continuous and Fix and Hold Integer Ambiguity Res.  I'll try to
attach screen shots of rtknavi.
Right now, it kind of works.  I can get relatively jitter-free floats and
occasionally fixes, but these fixes don't last long and I'm not sure they
are actually globally accurate (ie: if you restart the software, you may get
a fix, but it may be several meters from your last fix).  Sometimes a fix
goes away and never seems to come back.
I'm wondering if you guys have any suggestions to improve these results.
Better antennas? (Which ones?)
Trying to get better placement of the base station?
Different settings in rtknavi?
Continuous vs Fix and Hold?
Thanks!
-Sean
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140917/04981835/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140917/04981835/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140917/04981835/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140917/04981835/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140917/04981835/attachment-0003.png>
FOSS-GPS at lists.osgeo.org <mailto:FOSS-GPS at lists.osgeo.org>
End of FOSS-GPS Digest, Vol 68, Issue 7
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20140917/fd76a834/attachment-0001.html>
More information about the FOSS-GPS mailing list
