[FOSS-GPS] Different of algorithm between using GPS only and combined GPS+Glonass
solver90 salimzairmilk at hotmail.fr
Tue Apr 7 01:26:44 PDT 2015
Hello
The main difference between GPS and glonass (in term of localization
process) is in the number of parameter to estimate.
In GPS, you have 4 parameters : 3D position and clock bias
In Glonass, you have the same
but when you combine, the clocks of GPS and glonass are not the same, so:
In GPS+Glonass positioning, you have 5 parameter to estimate: 3D position,
GPS clock bias and Glonass clock bias.
Of course, you will have better precision because you use 2 times much more
data (less than two times).
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Different-of-algorithm-between-using-GPS-only-and-combined-GPS-Glonass-tp7573170p7573171.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
