[FOSS-GPS] Accurate timestamp in rtkpost
David Kelley DavidKelley at iTSware.net
Fri Dec 4 20:45:16 PST 2015
Musa:  What is your end goal here? Convert your data to RINEX with
RTKLIB's convert tool and look at when your measurement epochs actually
occurred.  Chances are that they are aligned to the second, and that is
what is driving you time alignment.  Can you have the Topcon output at a
rate greater then 1Hz, and then look at that?  As general rule, the
actual observation time stamp is precise to units steps of 100ns
(presuming that the nav filter will then resolve this further, to pSec
in the case of good RTK) , but the vast majority of devices will not
"wake up" with some random offset point and then provide 1Hz
measurements from that point, rather they will align to the current
second and give you the summed average of the range and range rate of
the past 1000 CA code intervals. Net result; you get 1Hz data aligned to
the second unless you work real hard.
Regards, David Kelley
On 12/4/2015 7:11 PM, ABM Musa wrote:
> Hi,
> I’m using a Topcon GR3 as a rover to collect some data and then post processing it with rtkpost along with data from a nearby CORS station. I’m using rover navigation and observation files, base-station observation file, and precise orbital file (sp3). However, the timestamp in the solution file is only with accuracy of whole seconds. Can you please let me know how I can get the timestamp accuracy in milliseconds?
> -Musa
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
