[FOSS-GPS] RTKGPS+ using RTCM with GPS+GLONASS not working
gto234 mersota at hotmail.com
Sat Dec 12 23:11:22 PST 2015
Ok, I finally figured it out. The port was blocked by some firewall settings.
Using the embedded NTRIP server of my L1/L2 reveiver I managed to connect it
to the Lefebure Caster and the corrections was on the internet. Then I
connected a L1 receiver to the caster with RTKGPS+ and got the corrections
from my base station.
All I need now is a good android data collector which reads the solution
from the RTKGPS+.
Thank you all for your answers.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKGPS-using-RTCM-with-GPS-GLONASS-not-working-tp7573332p7573377.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
