[FOSS-GPS] R: post-processing in RTKLib
Antonella Marsico antonella.marsico at uniba.it
Mon Jan 19 05:28:40 PST 2015
For the reference station all data are ok, but what does "reference
distance" mean?
my post-processing worked well and in the RTKPLOT (Gnd Trk) I see that my
data look like Kinematic survey. I suppose that the coordinates that I need
are those of the ORI in the statistic, since I need coordinates of one
point: is it correct?
Antonella Marsico, PhD
Dipartimento di Scienze della Terra e Geoambientali
Università degli Studi di Bari "Aldo Moro"
via E. Orabona 4 - 70125 Bari
email: antonella.marsico at uniba.it
skype: antonellamarsico
-----Messaggio originale-----
Da: foss-gps-bounces at lists.osgeo.org
[mailto:foss-gps-bounces at lists.osgeo.org] Per conto di julio menezes
Inviato: lunedì 19 gennaio 2015 12.52
A: Open Source GPS-related discussion and support
Oggetto: Re: [FOSS-GPS] post-processing in RTKLib
Dear Antonella Marisco,
Em seg, 19/1/15, Antonella Marsico <antonella.marsico at uniba.it> escreveu:
 Assunto: [FOSS-GPS] post-processing in RTKLib
 Para: foss-gps at lists.osgeo.org
 Data: Segunda-feira, 19 de Janeiro de 2015, 8:11
 Hello
 everybody,I'm new in RTKLib... I collected data in  static mode and I need
to correct measures using data from  an antenna of GNSS network. I used the
RTKPOST in both  Static and DGPS mode. I need the coordinates
(lat/long/height or X/Y/Z) of one point
>From reference station you will need:
a) Rinex Observation and Navigation  data
b) reference position Lat/Lon/Height ( geometric and orthometric if
available )
c) antenna height
Your location:
a) occupation time, depends receiver capabilities ( L1 or L1+L2 ... ) and
reference distance.
b) antenna height
the static technic is ok for you.
you must:
a) select static and frequencies, gps+glonass or just gps  ( rtkpost panel )
b ) type the base station position ( rtkpost panel )
c) other minor settings, let the default
regards,
julio menezes
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
subscription For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
