[FOSS-GPS] Required files/products for post-processed PPP
Dimitris Psychas psxdimitris at hotmail.com
Wed May 13 06:45:10 PDT 2015
I agree totally with you Mr Anders, but what about DCB products/files ? Is it that important to use them in the PPP-processing ? And if yes, are there any yearly/annual DCB files except for the daily ones? I am asking, because I want to process observations from many days, and I cannot change the daily file all the time.
Thank you in advance
Date: Mon, 11 May 2015 09:55:47 +0300
To: foss-gps at lists.osgeo.org
Subject: Re: [FOSS-GPS] Required files/products for post-processed PPP
Hi, fwiw some notes from mostly using NRCan's gpsppp, just testing ESA gLAB or rtklib once or twice. Receivers are dual-frequency so the ppp uses an 'ionosphere-free' linear combination - I don't have any experience with ionosphere corrections for single frequency receivers.
For the clock and orbit products, note that there are many variants: final (slow), rapid (1-2 days), and ultra-rapid (6h?) depending on what latency you can tolerate. For me Rapid products seem to yield almost identical results with Final producsts so I am using those. I haven't tried the ultra-rapid products.
Also some datacenters have CLK and EPH files with 30s data interval (the usual data interval in my RINEX files) but for long term storage they keep only data with 300s interval, so when using these the CLK and EPH numbers are interpolated - not sure about the effect on the position/time error.
ERP: earth-rotation-parameters, also from the IGS datacenter. Probably these do not change rapidly so you are ok even if not using the latest file.
igs08.atx my understanding is that this contains the receiver antenna phase center variations.
svb_gnss_yrly: satellite phase center variations?
OLC-file with ocean tide loading data in HARPOS format. afaik this is modeled as a weighted sum of spherical harmonics. These change slowly so you only need a new file maybe once a year. Onsala space obsevatory has a site that outputs parameters if you input the coordinates of your antenna.
After all of these inputs it seems that the variation among ppp-flavours (rtklib, gpsppp, ESA gLab, GIPSY, etc) is how they model troposhperic delay ZTD. These parameters can also be adjusted but I haven't seen guidelines for how to do it. I ran a comparison a while ago:
http://www.anderswallin.net/2013/12/comparing-gps-ppp-solutions/
The ppp-solution is a kind of digital filter, and many programs have the option of running the filter both forward and backward on the time-series, thus eliminating start/end transients. Not sure what is the best way to combine the FWD and BCKW solutions into one. A popular option seems to be to use teqc to concatenate many RINEX files into a long one, run the ppp-solution, and then just discard transients at start and end.
Discussion/comments welcome!
Anders
On Sat, May 9, 2015 at 11:59 AM, Dimitris Psychas <psxdimitris at hotmail.com> wrote:
Hey everyone,
I would like to ask about the required files that someone needs in order to estimate PPP solutions.
Besides the precise orbit and clock products (sp3 and clk), observation and navigation files, is there any other file that someone should use for PPP estimation ? Is it mandatory to include ANTEX files (atx, pcv) for antenna phase center variations, or DCB files ?
Afterwards, in the case of multi-GNSS post-processing PPP, MGEX has not published any MGEX ANTEX files, so is it fine if igs08.atx file is used within the processing ?
Thank you in advance.
Best regards,
Dimitris Psychas
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150513/4ba678d7/attachment-0001.html>
More information about the FOSS-GPS mailing list
