[FOSS-GPS] rtknavi vs rtkrcv
Fred Labrosse ffl at aber.ac.uk
Tue Nov 3 02:16:32 PST 2015
David and all,
But this input is not used (type is off).  In most cases, our computers are
not connected to the Internet (mobile base and robots in the field).
I still have not found out where rtkrcv stores the ephemeris data.  I had a
*quick* look at the sources to see if there was anything obvious, but I
couldn't see it if there was.
Cheers,
Fred
On Monday 02 November 2015 09:06:55 David Kelley wrote:
> Fred:
> I do not see why it would not work.
> The line
> inpstr3-path
> =anonymous:passwd at cddis.gsfc.nasa.gov/gps/products/%W/igu%W%D_%hb.sp3.Z:
> :T=-14400,21600,7200,600 seems correct to me.
> I need to review how the SP3 formats differs to be sure that RTK can
> consume it, we normally use Bcast orbits here, somewhere in the back of
> my mind was a mental note that SP3 was not supported in all the tools
> and all the flows.  If yoy are still seeing it work then now work in odd
> conditions, track down the temp directory and look very close at any
> other file it might be keeping a prior set of ephemeris in.
> Regards
>  David Kelley
> On 11/2/2015 1:00 AM, Fred Labrosse wrote:
> Hi David,
> Thank you for this very useful answer.  See below.
> On Friday 30 October 2015 12:05:23 David Kelley wrote:
> If I make it display the satellites, I most of the time don't get any,
> sometimes 1, sometimes a full set.
> Two questions to consider.  This makes me wonder if you are reliability
> getting ephemeris data.  Is that what you mean when you say you can not
> display the satellite?  In the configuration you have created, can you
> describe what is the path over which the ephemeris messages get to the
> navigation filter?
> I have no idea.  The only thing I can see that refers to ephemeris is set
> to broadcast.  I attach my config, in case it helps.
> [Aside: It took me quite a bit of trial and error and the help of other
> folks on this list to find out that RTKLIB stores recent past ephemeris
> data in the .ini files.  Sometime a config worked, sometimes it did
> not.  Turned out the data from a recent past run was still present. I
> learned to edit the end of the ini file to remove this when I wanted to
> test out cold starting issues. Perhaps you are seeing something of the
> same sort.
> PS these lines look like:
> eph_01=G02,38,38,0,0,14460624...0,
> eph_04=G05,96,96,0,0,14460......
> eph_11=G12,63,63,0,0,1446....  etc.     ]
> This is interesting.  I was wondering about that because it seems that
> the receivers I use do not store that (NV08C).  What would be the
> eequivalent for rtkrcv?  I have looked but couldn't find an equivalent.
> Cheers,
> Fred
> On 10/30/2015 10:19 AM, Fred Labrosse wrote:
> All,
> I have been trying to use the unix applications, after getting good
> results with the Windows ones.
> I now have a (unix) server that serves data from one receiver for now
> and if I connect rtknavi (windows) to it in PPP-static I get a fix
> quite quickly.  If at the same time I connect rtkrcv to the same
> server, the result is not so good.  If I make it display the
> observations (observ 1), I do get data that is similar to what I see
> in rtknavi.  If I make it display the satellites, I most of the time
> don't get any, sometimes 1, sometimes a full set.  This seems to be
> random between stop/starts.  Waiting does not seem to help.	If I
> manage to get a fix in rtkrcv, stop and restart it, usually I don't
> get a fix.  However, if I do the same in rtknavi, I get a fix almost
> immediately.
> What have I missed?
> Cheers,
> Fred
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription For more information, check
> http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
