[FOSS-GPS] RTKlib using GPS and GLONASS
BREMAUD Jean-Charles Jean-Charles.BREMAUD at sercel.com
Tue Sep 1 01:53:27 PDT 2015
I 'm currently trying to use rtklib with GPS and GLONASS using L1 only signal, and I never got a fix.
Various tests were performed in :
-          post-processing mode (RTKPOST) in static and single, with various types of receiver (Ublox M8 raw data , and from national French CORS stations)
-          real-time (RTKNAVI) in static and single (Ublox M8 are used as raw data sources)
In GPS only all tests are OK, but when Glonass is activated no way to have a fix.
For each epoch, the returned error message is always : point pos error (chi-square error nv=9 vv=882.4 cs=13.8)
Using RTKMonitor in RTKNAVI, I can see that residuals are very high.
Any ideas, or suggestions ?
Thanks for your help.
Jean-Charles
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150901/058faefb/attachment.html>
More information about the FOSS-GPS mailing list
