[FOSS-GPS] RTKlib using GPS and GLONASS
arwooldridge arwooldridge at googlemail.com
Tue Sep 1 03:30:35 PDT 2015
Did you switch off integer ambiguity resolution for Glonass under
"Options/Setting2" in RTKnavi?
Leave it enable for GPS
This is necesary when using GPS plus GLO otherwise a good fix is almost
certainly not possible.
Regards
Anthony
On 01/09/2015 09:53, BREMAUD Jean-Charles wrote:
> Hi,
> I ‘m currently trying to use rtklib with GPS and GLONASS using L1 only
> signal, and I never got a fix.
> Various tests were performed in :
> -post-processing mode (RTKPOST) in static and single, with various
> types of receiver (Ublox M8 raw data , and from national French CORS
> stations)
> -real-time (RTKNAVI) in static and single (Ublox M8 are used as raw
> data sources)
> In GPS only all tests are OK, but when Glonass is activated no way to
> have a fix.
> For each epoch, the returned error message is always : point pos error
> (chi-square error nv=9 vv=882.4 cs=13.8)
> Using RTKMonitor in RTKNAVI, I can see that residuals are very high.
> Any ideas, or suggestions ?
> Thanks for your help.
> Jean-Charles
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150901/57ec7ff5/attachment.html>
More information about the FOSS-GPS mailing list
