[FOSS-GPS] Hemisphere A101 smart antenna & RTKlib. Commands at startup
dskumher dskumher1968 at gmail.com
Sat Aug 27 10:20:41 PDT 2016
The receiver you mentioned is crescent based receiver. The following commands
at startup & end I used for similar receiver old hemisphere A100 smart
antenna with success.These must also work for your receiver also.These are
for 1 Hz update rate (Replace number 1 by the desired update rate)
At start up:
$JBIN,94,1
$JBIN,95,1
$JBIN,96,1
$JBIN,80,1
At end :
$JBIN,94,0
$JBIN,95,0
$JBIN,96,0
$JBIN,80,0
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Hemisphere-A101-smart-antenna-RTKlib-Commands-at-startup-tp7573476p7573520.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
