[FOSS-GPS] FoxtrotGPS - POI and other stuff
David Bannon dbannon at internode.on.net
Thu Dec 15 03:14:22 PST 2016
On 15/12/16 20:52, Sezer Yalcin wrote:
> Just for #1
> Sqlite is very common database. You can use available C libraries or
> deal with it use simpler scripting languages like PHP
> https://secure.php.net/manual/en/book.sqlite3.php
Yes, thanks Sezer. I should have chosen my words more carefully. What I
want to know is the database schema, the names of the database columns
and what sort of data foxtrot expects to find in there. If I could find
an (Foxtrot POI) example file, I could use sqlite to dump the schema but
I have not found anything like one.
But thanks for your response anyway.
David
> On Thu, Dec 15, 2016 at 12:40 PM, David Bannon
> <dbannon at internode.on.net <mailto:dbannon at internode.on.net>> wrote:
>     Hi Folks, some questions about FoxtrotGPS ?
>     1. Reference is made to the poi.db, an sqlite database. Anyone
>     know where the format of that file is documented ? I might be able
>     to work it out from poi.c but not very keen.
>     2. My install of Foxtrot does not have any mention of poi in
>     menus, is that because the Ubuntu build chooses to not support poi ?
>     3. Assuming above, I grabbed source but the INSTALL file with
>     building instructions seems to have gone away. Those instructions
>     exist on the web site, should we make a new INSTALL file or remove
>     reference to it from README ?
>     4. In Contributions, the script, gpx2osm, line 26 says "...osm
>     version='0.5'...". OSM now requires version 0.6, fortunately, what
>     we are doing here is unchanged with the version boost so its a
>     simple edit, change 0.5 to 0.6
>     5. Do you want a "pull request" or what ever Launchpad uses to do
>     3 and 4 of this ?
>     David
>     _______________________________________________
>     This message is sent to you from FOSS-GPS at lists.osgeo.org
>     <mailto:FOSS-GPS at lists.osgeo.org> mailing list.
>     Visit http://lists.osgeo.org/mailman/listinfo/foss-gps
>     <http://lists.osgeo.org/mailman/listinfo/foss-gps> to manage your
>     subscription
>     For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>     <http://wiki.osgeo.org/wiki/FOSS-GPS>
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20161215/de10fa74/attachment.html>
More information about the FOSS-GPS mailing list
