[FOSS-GPS] Precise Heading Determination
anthony wooldridge arwooldridge at googlemail.com
Sun Jan 10 12:13:08 PST 2016
Hi Rick,
Use moving base mode.
The RTKnavi gui can give angle of rover relative to base.
It should be fairly easy to extract it.
Regards Anthony
On 10/01/2016 14:50, RickHwang wrote:
> Hi,
> Using two antennas at fixed distance from each other and two raw measurement
> receivers to determine heading direction of a boat, is there a way to
> calculate precise heading using RTKLIB?
> Thanks a lot.
> Rick
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Precise-Heading-Determination-tp7573389.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
