[FOSS-GPS] How to compile new RTKLIB 2.4.3 B11?
Tomoji Takasu ttaka at yk.rim.or.jp
Tue Jun 21 01:40:59 PDT 2016
> Thanks I had the same problem now fixed, compiles OK but now get linker
> error:
> c:\program files
> (x86)\embarcadero\studio\18.0\Bin\CodeGear.Cpp.Targets(3517,5): error :
> Error: Unresolved external '__fastcall
> Vcl::Controls::TWinControl::GetDeviceContext(void *&)' referenced from
> C:\RTKLIB ARW
> FORK\RTKLIB-RTKLIB_2.4.3B12\APP\RTKNAVI\RELEASE_BUILD\NAVIMAIN.OBJ
> and two other similar unresolved external errors
> fixed three fabs long double/ float ambiguity errors by changing to fabsl
> Using C++ builder 10.1 Berlin.
Thanks for useful info.
I used C++ builder XE2 starter (32bit) and have no
problem.
Some modification may be needed for 10.1 Berlin.
Tomoji TAKASU
From: "anthony wooldridge" <arwooldridge at googlemail.com>
Sent: Tuesday, June 21, 2016 5:34 PM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] How to compile new RTKLIB 2.4.3 B11?
> error:
> c:\program files
> C:\RTKLIB ARW
> Regards
> Anthony
> On 21/06/2016 05:44, Tomoji Takasu wrote:
>>> Where is file markdlg.h?
>>> i not found
>> Thanks. It is fixed in 2.4.3 b12.
>> Tomoji TAKASU
>> From: "cocute" <cocute at gmail.com>
>> Sent: Monday, June 20, 2016 9:37 PM
>> To: <foss-gps at lists.osgeo.org>
>> Subject: [FOSS-GPS] How to compile new RTKLIB 2.4.3 B11?
>>> y have this error:
>>> [bcc32 Error] navimain.cpp(35): E2209 Unable to open include file
>>> 'markdlg.h'
>>> i not found
>>> Thanks
>>> View this message in context:
>>> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/How-to-compile-new-RTKLIB-2-4-3-B11-tp7573495.html
>>> Sent from the Open Source GPS-related discussion and support mailing
>>> list archive at Nabble.com.
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>>> subscription
>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>> subscription
> subscription
More information about the FOSS-GPS mailing list
