[FOSS-GPS] gap in base observations unsettles RTKPOST indefinitely
anthony wooldridge arwooldridge at googlemail.com
Wed Jun 22 05:37:28 PDT 2016
Hi Michele,
I too have noticed irretrievable recovery after loss of fix eg base
rover communication etc.
Possible some ideas from rtklibexplorer may help have you tried his
demo3 branch, and other good ideas re recovering from fix and hold ?
Regards
Anthony
On 22/06/2016 13:06, Michele Bavaro wrote:
> Hello,
> I am doing Kinematic between base (LLH = 44.434828231 12.300198659
> 45.9096) and rover.
> The rover has 4Hz.
> The base has normally 0.2 Hz rate, but across midnight experiences a
> gap of about 90 seconds.
> So the age of differential correctly grows and solution goes from 1
> (fix) to 5 (single).
> However when the base eventually comes back, a perfectly good set of
> observations pushes the EKF so far that AR does not recover anymore.
> So far I am solving this by adding
> memset(rtk->x, 0, rtk->nx*sizeof(double)); /** RESET FLOAT STATES?? */
> in /rtkpos.c/ after
> errmsg(rtk,"age of differential error (age=%.1f)\n",rtk->sol.age);
> However, my fix looks dirty and the problem should not manifest in the
> first place?
> So far I am guessing the problem is here:
>         if
> ((nv=ddres(rtk,nav,dt,xp,Pp,sat,y,e,azel,iu,ir,ns,v,H,R,vflg))<1) {
> inside relpos() in /rtkpos.c/.
> My feeling is that the age of correction when the base wakes up is
> said to be 0.2 seconds when in reality more than 90 have passed and so
> the partial derivatives go off scale?
> Such behavior, if confirmed, may impair any real-life situation in
> which base and rover talk unreliably between each other...
> All data are here:
> https://www.dropbox.com/s/igwt9jsh8pco1bs/160531n-aann.zip?dl=0
> Can anybody comment on this and propose a cleaner fix?
> Cheers,
> Michele
> P.S.: This happens with both 2.4.2b11 and 2.4.3b12
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160622/8bd8c17c/attachment.html>
More information about the FOSS-GPS mailing list
