[FOSS-GPS] Ublox M8T, unable to receive data
xeee fabiomonteiro3 at hotmail.com
Wed Mar 2 07:56:53 PST 2016
After you run the command "rtkrcv -o ublox.conf" you need to write "start"
Or instead you can run "rtkrcv -s -o ublox.conf"
Don't forget to check the other command that you will probably need...
http://www.rtklib.com/prog/manual_2.4.2.pdf
Page 92 of the manual... status, stream, observ, navigate, satellite,
error....
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/ublox-NL-6002U-tp7573396p7573401.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
