[FOSS-GPS] Reading rtkrcv under GNU/Linux rtklib: PPP-static precision mode
xeee fabiomonteiro3 at hotmail.com
Thu Mar 3 09:59:40 PST 2016
Hey,
I never used the m8t but in the configuration file there is this line,
pos1-navsys        =1          # (1:gps+2:sbas+4:glo+8:gal+16:qzs+32:comp)
So you add the systems you want to use, 1= GPS, 5=GPS+GLO,
7=GPS+GLO+SBAS....
You have examples of configuration files in the folder ./app/rtkrcv/
Maybe its better if you change those files instead of using one with only
the commands you have.
I only started using rtklib in January so I'm also still new to this
In my last PPP solution I got the pos xyz float std (m) rover : 0.024,
0.011, 0.021, so you still have room to improve.
No fancy settings but I left the rtkrcv running for almost 5hours at 10Hz.
Anyway, you are using rtklib 2.4.2, there is already the 2.4.3b8 in Github
so maybe its a good idea to update to the new one.
There are a lot of updates in the latest ublox files used.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Reading-rtkrcv-under-GNU-Linux-rtklib-PPP-static-precision-mode-tp7573416p7573421.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
