[FOSS-GPS] uBlox NEO-M8T and RTKlib
arwooldridge@googlemail.com arwooldridge at googlemail.com
Tue Mar 22 03:45:42 PDT 2016
Hi, try the start-up command files in the data folder of rtk2.4.3b8.
if they don't work, set up m8t in ucenter and save to flash.
in options/ position/base position, set to rtcm antenna position.
Regards Anthony
Sent from my HTC
----- Reply message -----
To: <foss-gps at lists.osgeo.org>
Subject: [FOSS-GPS] uBlox NEO-M8T and RTKlib
Date: Mon, Mar 21, 2016 21:27
Hi to all!
I'm new here, so I ask if there is someone that can help on configuring
a M8T module (what string is needed?) to work with RTKlib? And how to
configure RTKlib to deal with that module. Or maybe you can direct me to
some webpages/guides where I can find some help?
I have a Neo M8T module with fw 2.30 and try to use rtklib v2.4.3b8. I
have a d-gps station 10 km away from my location and want to use the
data from this station to correct the data from uBlox module (in
real-time and/or post-process)...
Thank you in advace
Damjan G.
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160322/6ba4152d/attachment.html>
More information about the FOSS-GPS mailing list
