[FOSS-GPS] uBlox NEO-M8T and RTKlib
anthony wooldridge arwooldridge at googlemail.com
Wed Mar 23 02:25:47 PDT 2016
try ubx_m8t_glo_raw_5hz.cmd
1 hz is sufficient for base station, but use 5 hz or 10 hz rover data
depending on your application requirements.
the command file did not work for me in firmware 3.01 so had to set up
in ucenter,
enable msg rxm rawx, and rxm sbfrx for usb or serial depending on module
used.
set gps plus glo plus sbas
switch off nmea ouputs to conserve stream data rates or set nav rate to
1 hz.
goo to tools gnss configuration and tick save to flash.
Regards
Anthony
On 22/03/2016 22:52, Damjan Gerl wrote:
> 22.03.2016 - 11:45 - arwooldridge at googlemail.com:
>> Hi, try the start-up command files in the data folder of rtk2.4.3b8.
> Thank you. I check and I have this commands:
> ubx_m8t_bds_raw_1hz.cmd
> ubx_m8t_bds_raw_5hz.cmd
> ubx_m8t_glo_raw_1hz.cmd
> ubx_raw_1hz.cmd
> ubx_raw_5hz.cmd
> ubx_raw_10hz.cmd
> What I must use for gps+glo? I have 1s correction from station, so it
> is better to use 1hz or 5hz (or 10)?
> Thank you
> Damjan
>> if they don't work, set up m8t in ucenter and save to flash.
>> in options/ position/base position, set to rtcm antenna position.
>> Regards Anthony
>> Sent from my HTC
>> ----- Reply message -----
>> From: "Damjan Gerl" <damjan at damjan.net>
>> To: <foss-gps at lists.osgeo.org>
>> Subject: [FOSS-GPS] uBlox NEO-M8T and RTKlib
>> Date: Mon, Mar 21, 2016 21:27
>> Hi to all!
>> I'm new here, so I ask if there is someone that can help on configuring
>> a M8T module (what string is needed?) to work with RTKlib? And how to
>> configure RTKlib to deal with that module. Or maybe you can direct me to
>> some webpages/guides where I can find some help?
>> I have a Neo M8T module with fw 2.30 and try to use rtklib v2.4.3b8. I
>> have a d-gps station 10 km away from my location and want to use the
>> data from this station to correct the data from uBlox module (in
>> real-time and/or post-process)...
>> Thank you in advace
>> Damjan G.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
