[FOSS-GPS] uBlox NEO-M8T and RTKlib
Tomoji Takasu ttaka at yk.rim.or.jp
Wed Mar 23 17:51:54 PDT 2016
Dear Anthony,
> Is AR enabled automatically for Gallileo? there's no button to switch on
> /off.
For Galileo, I think no need of the AR-skip option.
> PS I am still getting trouble with STRSVR conversions of raw data to RTCM3
> even with MSM messages. Bad glitches every few hours that does not occur
> using raw data direct.
I will check it. Please send sample log files for original raw
and converted MSM to rtklib_support(a)gpspp.sakura.ne.jp.
regards,
Tomoji TAKASU
From: "anthony wooldridge" <arwooldridge at googlemail.com>
Sent: Wednesday, March 23, 2016 10:25 PM
To: "Open Source GPS-related discussion and support"
<foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] uBlox NEO-M8T and RTKlib
> Dear Tomoji,
> Thanks, I did try cmd files in 2.4.3b8 GPs+Glo 5Hz but something still
> wrong somewhere, will have to investigate further.
> Now seeing 2-4 Gallileo satelites :)
> /off.
> Regards
> Anthony
> On 23/03/2016 09:38, Tomoji Takasu wrote:
>> Dear Anthony,
>>> the command file did not work for me in firmware 3.01 so
>>> had to set up in ucenter, enable msg rxm rawx, and rxm sbfrx for usb or
>>> serial depending on module used.
>> In 3.01 the format of RXM-CFG-GNSS is slightly modified.
>> So use the command files in 2.4.3 b8 for F/W 3.01.
>> regards,
>> Tomoji TAKASU
>> Sent: Wednesday, March 23, 2016 6:25 PM
>>> try ubx_m8t_glo_raw_5hz.cmd
>>> 1 hz is sufficient for base station, but use 5 hz or 10 hz rover data
>>> depending on your application requirements.
>>> the command file did not work for me in firmware 3.01 so had to set up
>>> in ucenter,
>>> enable msg rxm rawx, and rxm sbfrx for usb or serial depending on module
>>> used.
>>> set gps plus glo plus sbas
>>> switch off nmea ouputs to conserve stream data rates or set nav rate to
>>> 1 hz.
>>> goo to tools gnss configuration and tick save to flash.
>>> Regards
>>> Anthony
>>> On 22/03/2016 22:52, Damjan Gerl wrote:
>>>> 22.03.2016 - 11:45 - arwooldridge at googlemail.com:
>>>>> Hi, try the start-up command files in the data folder of rtk2.4.3b8.
>>>> Thank you. I check and I have this commands:
>>>> ubx_m8t_bds_raw_1hz.cmd
>>>> ubx_m8t_bds_raw_5hz.cmd
>>>> ubx_m8t_glo_raw_1hz.cmd
>>>> ubx_raw_1hz.cmd
>>>> ubx_raw_5hz.cmd
>>>> ubx_raw_10hz.cmd
>>>> What I must use for gps+glo? I have 1s correction from station, so it
>>>> is better to use 1hz or 5hz (or 10)?
>>>> Thank you
>>>> Damjan
>>>>> if they don't work, set up m8t in ucenter and save to flash.
>>>>> in options/ position/base position, set to rtcm antenna position.
>>>>> Regards Anthony
>>>>> Sent from my HTC
>>>>> ----- Reply message -----
>>>>> From: "Damjan Gerl" <damjan at damjan.net>
>>>>> To: <foss-gps at lists.osgeo.org>
>>>>> Subject: [FOSS-GPS] uBlox NEO-M8T and RTKlib
>>>>> Date: Mon, Mar 21, 2016 21:27
>>>>> Hi to all!
>>>>> I'm new here, so I ask if there is someone that can help on
>>>>> configuring
>>>>> a M8T module (what string is needed?) to work with RTKlib? And how to
>>>>> configure RTKlib to deal with that module. Or maybe you can direct me
>>>>> to
>>>>> some webpages/guides where I can find some help?
>>>>> I have a Neo M8T module with fw 2.30 and try to use rtklib v2.4.3b8. I
>>>>> have a d-gps station 10 km away from my location and want to use the
>>>>> data from this station to correct the data from uBlox module (in
>>>>> real-time and/or post-process)...
>>>>> Thank you in advace
>>>>> Damjan G.
>>>> _______________________________________________
>>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>>>> subscription
>>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>>> subscription
>> subscription
> subscription
More information about the FOSS-GPS mailing list
