[FOSS-GPS] uBlox NEO-M8T and RTKlib
Tomoji Takasu ttaka at yk.rim.or.jp
Wed Mar 23 18:53:59 PDT 2016
Dear Damjan,
> I have already downloaded fw 3.01 to my pc but not yet updated the module.
> Do you think that it is worth to update from 2.30 to 3.01 also if official
> ublox statement is that this fw is not compatible with NEO-M8T.
I myself already am successful to update 2 x LEA-M8T and
1 x NEO-M8T to 3.01 by using M8N F/W. It enables Galileo
and 10 Hz raw-data. RTKLIB 2.4.3 b8 also enables Galileo
navigation data.
However, u-blox officially does not ensure M8N F/W for M8T.
Actually, my colleague failed to upgrade M8T F/W. In this
case, M8T could be used only as M8N (F/W 2.01).
So I don't recommend M8T F/W update. If you try, do it in
your own risk.
regards,
Tomoji TAKASU
Sent: Thursday, March 24, 2016 9:51 AM
To: <foss-gps at lists.osgeo.org>
Subject: Re: [FOSS-GPS] uBlox NEO-M8T and RTKlib
> 23.03.2016 - 10:38 - Tomoji Takasu:
>> Dear Anthony,
>>> the command file did not work for me in firmware 3.01 so
>>> had to set up in ucenter, enable msg rxm rawx, and rxm sbfrx for usb or
>>> serial depending on module used.
>> In 3.01 the format of RXM-CFG-GNSS is slightly modified.
>> So use the command files in 2.4.3 b8 for F/W 3.01.
>> regards,
>> Tomoji TAKASU
> BTW is there someone that have the 2.30 fw to downgrade in case of need
> (if it is possible)?
> BR,
> Damjan G.
>> From: "anthony wooldridge" <arwooldridge at googlemail.com>
>> Sent: Wednesday, March 23, 2016 6:25 PM
>> To: "Open Source GPS-related discussion and support"
>>> try ubx_m8t_glo_raw_5hz.cmd
>>> 1 hz is sufficient for base station, but use 5 hz or 10 hz rover data
>>> depending on your application requirements.
>>> the command file did not work for me in firmware 3.01 so had to set up
>>> in ucenter,
>>> enable msg rxm rawx, and rxm sbfrx for usb or serial depending on module
>>> used.
>>> set gps plus glo plus sbas
>>> switch off nmea ouputs to conserve stream data rates or set nav rate to
>>> 1 hz.
>>> goo to tools gnss configuration and tick save to flash.
>>> Regards
>>> Anthony
>>> On 22/03/2016 22:52, Damjan Gerl wrote:
>>>> 22.03.2016 - 11:45 - arwooldridge at googlemail.com:
>>>>> Hi, try the start-up command files in the data folder of rtk2.4.3b8.
>>>> Thank you. I check and I have this commands:
>>>> ubx_m8t_bds_raw_1hz.cmd
>>>> ubx_m8t_bds_raw_5hz.cmd
>>>> ubx_m8t_glo_raw_1hz.cmd
>>>> ubx_raw_1hz.cmd
>>>> ubx_raw_5hz.cmd
>>>> ubx_raw_10hz.cmd
>>>> What I must use for gps+glo? I have 1s correction from station, so it
>>>> is better to use 1hz or 5hz (or 10)?
>>>> Thank you
>>>> Damjan
>>>>> if they don't work, set up m8t in ucenter and save to flash.
>>>>> in options/ position/base position, set to rtcm antenna position.
>>>>> Regards Anthony
>>>>> Sent from my HTC
>>>>> ----- Reply message -----
>>>>> From: "Damjan Gerl" <damjan at damjan.net>
>>>>> Subject: [FOSS-GPS] uBlox NEO-M8T and RTKlib
>>>>> Date: Mon, Mar 21, 2016 21:27
>>>>> Hi to all!
>>>>> I'm new here, so I ask if there is someone that can help on
>>>>> configuring
>>>>> a M8T module (what string is needed?) to work with RTKlib? And how to
>>>>> configure RTKlib to deal with that module. Or maybe you can direct me
>>>>> to
>>>>> some webpages/guides where I can find some help?
>>>>> I have a Neo M8T module with fw 2.30 and try to use rtklib v2.4.3b8. I
>>>>> have a d-gps station 10 km away from my location and want to use the
>>>>> data from this station to correct the data from uBlox module (in
>>>>> real-time and/or post-process)...
>>>>> Thank you in advace
>>>>> Damjan G.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
