[FOSS-GPS] NVS08C CSM problem
julio menezes yjmenezes at yahoo.com.br
Thu Jan 26 02:55:12 PST 2017
@Alejandra
1- you most set NVS to log raw BINR
2- you can not use Trimble converter, it works with Trimble data format. Use rtklib  rtkconv or convbin.
3- if you like,  attach the NVS logged file and i will take a look if it is ok.
[]sjulio
      De: Alejandra Zamora Maciel <alejandra.zamora.facite at uas.edu.mx>
 Para: foss-gps at lists.osgeo.org
 Enviadas: Quarta-feira, 25 de Janeiro de 2017 16:22
 Assunto: [FOSS-GPS] NVS08C CSM problem
Hello everyone!!
I just bought a NVS08C-CSM and a Talysman antenna and I have a problem with the output file.
I use the STOREGIS,  I get a file .dat and at the moment of convert to RINEX it says that I don't have anything. For convert to RINEX I used "Convert to RINEX" by Trimble and RTKCONV
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20170126/9723ffc5/attachment.html>
More information about the FOSS-GPS mailing list
