[FOSS-GPS] Base station coordinate selection
atanu santra bubunhhh at gmail.com
Sat Apr 27 12:20:59 PDT 2019
Dear sir,
If you have dual frequency GPS rinex 2.xx data , you will obtain the true
position of your base antenna using online processing services named
'AUSPOS ' or 'OPUS' and you can put the true value at base coordinate.
These services uses precise ephemeris and clock and IGS stations to compute
your true location.
Best regards,
Atanu Santra
Junior research fellow
GNSS Laboratory
Department of Physics
The University of Burdwan
Golapbag, Burdwan
India
On Sun, 28 Apr 2019 12:30 am <foss-gps-request at lists.osgeo.org wrote:
> Send FOSS-GPS mailing list submissions to
>         foss-gps at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/foss-gps
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         foss-gps-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of FOSS-GPS digest..."
> Today's Topics:
>    1. [RTKlib RTKpost] Manually insert approximate coordinates  form
>       RINEX (kjerstiensrud)
> Message: 1
> Date: Sat, 27 Apr 2019 11:14:27 -0700 (MST)
> From: kjerstiensrud <kjersti.ensrud at outlook.com>
> To: foss-gps at lists.osgeo.org
> Subject: [FOSS-GPS] [RTKlib RTKpost] Manually insert approximate
>         coordinates     form RINEX
> Message-ID: <1556388867809-0.post at n2.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> I have been processing vectors and I had problems with the Base Station
> coordinates. The solution I found a few months ago was to manually input
> the
> approximate coordinates from the RINEX-file as X/Y/Z-ECEF and insert the
> antenna height. And input the atx-file in files. Does anyone know if this
> is
> an acceptable solution?
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/file/t395125/options_position.jpg>
> Kind Regards
> Kjersti
> Sent from:
> Subject: Digest Footer
> FOSS-GPS at lists.osgeo.org
> End of FOSS-GPS Digest, Vol 112, Issue 5
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20190428/80731fb2/attachment.html>
More information about the FOSS-GPS mailing list
