[FOSS-GPS] RTKlib help pls
Bud Asterisk budasterisk at gmail.com
Mon Nov 18 15:16:52 PST 2019
Hi folks,
I have been playing with the RTKlib packages for a few months now. Current
setup is 2 CSG M8T receivers. Each connected to a Raspberry Pi Zero W. The
pi run str2str that I compiled on the pi. These connect to RTKNAVI on my
laptop without issue, all over wifi. Have 2 cell phones ready to handle the
data connection so I can take it out into the wild! No problems at this
point.
I want to use RTKRCV which I have compiled on a linux machine. Am able to
make config changes but the tool is telling me to restart after I make a
config change. Here is what I am doing:
rtkrcv> help rtkrcv ver.2.4.2 start : start rtk server stop : stop rtk
server restart : restart rtk sever solution [cycle] : show solution status
[cycle] : show rtk status satellite [-n] [cycle]: show satellite status
observ [-n] [cycle] : show observation data navidata [cycle] : show
navigation data stream [cycle] : show stream status error : show
error/warning messages option [opt] : show option(s) set opt [val] : set
option load [file] : load options from file save [file] : save options to
file log [file|off] : start/stop log to file help|? [path] : print help
exit : exit and logout console shutdown : shutdown rtk server !command
[arg...]: execute command in shellrtkrcv> restart sh: 1: ./rtkstart.sh: not
foundcommand exec error: ./rtkstart.sh (32512)rtk server start errorrtkrcv>
start sh: 1: ./rtkstart.sh: not foundcommand exec error: ./rtkstart.sh
(32512)rtk server start errorrtkrcv> stop rtk server stoprtkrcv> start sh:
1: ./rtkstart.sh: not foundcommand exec error: ./rtkstart.sh (32512)rtk
It cant seem to find the start or restart commands....any wisdom? I only
did the compile of rtkrcv and no others.
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20191118/44cb9886/attachment.html>
More information about the FOSS-GPS mailing list
