[FOSS-GPS] RTKlib help pls
drwho drwho at infidigm.net
Tue Nov 19 17:37:59 PST 2019
I gave rtkrcv a try from https://github.com/rtklibexplorer/RTKLIB demo5
branch and voila, I get a float solution now!  No more no
double-differenced residual after 7 weeks of struggling!  Thank you so
much for pointing out rtklibexplorer.  Now onto getting a fixed
solution.  Any idea about how many valid satellites are required for a
fixed solution?  I'm getting 7 right now in the city, overcast....
# of satellites rover       : 11
# of satellites base        : 10
# of valid satellites       : 7
2019/11/20 01:37:22.00 G07 1 23543275.469        0.000
123720746.574         0.000 2914.1     0.0 37  064 0
2019/11/20 01:37:22.00 G08 1 22171781.133        0.000
116513507.383         0.000  3244.9     0.0 45  0 0 0
2019/11/20 01:37:22.00 G09 1 21126139.602        0.000
111018592.926         0.000   448.3     0.0 38  064 0
2019/11/20 01:37:22.00 G16 1 20963946.320        0.000
110166281.117         0.000 -2187.3     0.0 46  0 0 0
2019/11/20 01:37:22.00 G21 1 25155113.438        0.000
132191029.602         0.000   141.0     0.0 31  064 0
2019/11/20 01:37:22.00 G23 1 20989052.875        0.000
110298206.492         0.000 -1256.4     0.0 35  0 0 0
2019/11/20 01:37:22.00 G26 1 22904042.680        0.000
120361516.371         0.000 -2944.8     0.0 46  064 0
2019/11/20 01:37:22.00 G27 1 20758214.352        0.000
109085174.746         0.000  1349.3     0.0 47  064 0
2019/11/20 01:37:22.00 R14 1 20121058.617        0.000
107256576.695         0.000 -1320.0     0.0 44  0 0 0
2019/11/20 01:37:22.00 R15 1 20369659.602        0.000
108849285.676         0.000  1616.6     0.0 38  0 0 0
2019/11/20 01:37:22.00 R23 1 21825182.789        0.000
116750015.395         0.000 -1661.8     0.0 46  0 0 0
2019/11/20 01:37:22.00 G08 2 22171770.695        0.000
116513422.930         0.000  3245.4     0.0 30  064 0
2019/11/20 01:37:22.00 G09 2 21126127.297        0.000
111018526.246         0.000   448.2     0.0 39  0 0 0
2019/11/20 01:37:22.00 G16 2 20963933.781        0.000
110166180.230         0.000 -2187.4     0.0 47  0 0 0
2019/11/20 01:37:22.00 G21 2 25155108.125        0.000
132190973.727         0.000   140.0     0.0 42  0 0 0
2019/11/20 01:37:22.00 G23 2 20989045.883        0.000
110298167.875         0.000 -1256.6     0.0 36  0 0 0
2019/11/20 01:37:22.00 G26 2 22904033.281        0.000
120361469.652         0.000 -2944.8     0.0 44  064 0
2019/11/20 01:37:22.00 G27 2 20758202.812        0.000
109085095.344         0.000  1349.2     0.0 48  0 0 0
2019/11/20 01:37:22.00 R05 2 20871721.062        0.000
111571326.961         0.000 -1165.9     0.0 33  0 0 0
2019/11/20 01:37:22.00 R14 2 20121049.281        0.000
107256486.191         0.000 -1319.6     0.0 47  064 0
2019/11/20 01:37:22.00 R24 2 20960371.930        0.000
112084524.137         0.000  1858.1     0.0 40  064 0
Jon
On 2019-11-19 5:13 p.m., Bud Asterisk wrote:
> OK gang.....good news!
> I used the latest source for rtkrcv from rtklibexplorer's repo and
> compiled it on my google cloud instance. Also used my conf file I had
> working in rtknavi since it had been tweaked for me. Here is my setup.
> 2 CSG M8T boards, each connected to a Raspberry Pi Zero W. They have
> str2str compiled and streaming the data to the google VM of rtkrcv.
> Attached is a screencapture of 3 terminals, 2 of the PI and one of the
> rtksrv output stream of the rover location. Sorry I blacked out the IP
> and location info for security reasons. Right now the antennas are in
> my window facing south so it is only a float solution that comes and
> and goes. Not sure it attachments will make it through the list....
> Bud
> Oh here is a cut and paste of the output stream. IP and location info
> has been fudged
> 2019/11/19 22:12:40.000   21.134425586  -42.963204887 452.7045   2   4
>   0.2230   0.1686   0.5208  -0.1212  -0.1373  -0.1447   1.00    0.0
> Right after the elevation of 452 you can see the "2" as solution type
> which is enumated as float.
> On Tue, Nov 19, 2019 at 9:13 AM drwho <drwho at infidigm.net
> <mailto:drwho at infidigm.net>> wrote:
>     On 2019-11-19 8:35 a.m., Bud Asterisk wrote:
>     > I will try the CUI code from here:
>     > Is this what you are using as well? His binaries on windows work
>     for
>     > me to get FIX.
>     The rtkrcv I have been using is from
>     https://github.com/tomojitakasu/RTKLIB.git
>     branch = 2.4.3b33
>     http://www.rtklib.com/ points to this git repo.
>     I'll try the rtkrcv from rtklibexplorer tonight
>     Jon
>     _______________________________________________
>     This message is sent to you from FOSS-GPS at lists.osgeo.org
>     <mailto:FOSS-GPS at lists.osgeo.org> mailing list.
>     Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage
>     your subscription
>     For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20191119/9c1273b0/attachment.html>
More information about the FOSS-GPS mailing list
