[FOSS-GPS] librtk newbie
drwho
drwho at infidigm.net
Sat Sep 28 10:30:19 PDT 2019
I am trying to use rtkrcv (for the first time) in librtk with a oemstar
board. I think the oemstar is compatible with oem4. I have used oem4
in rtkrcv.conf. rtkrcv appears to be communicating with the oemstar
because when I issue status and obverv commands, I see satellites, but
no valid satellites.....
rtkrcv> observ
TIME(GPST) SAT R P1(m) P2(m) L1(cyc) L2(cyc) D1(Hz)
D2(Hz) S1 S2 LLI
17:24:01.0 G02 1 22541061.66 0.00 119276073.82 0.00 -2211.7
0.0 46 0 0 0
17:24:01.0 G05 1 20733957.26 0.00 108957666.41 0.00 -1710.2
0.0 50 0 0 0
17:24:01.0 G07 1 25444131.91 0.00 133709819.71 0.00 -7.2
0.0 42 0 0 0
17:24:01.0 G13 1 21117208.30 0.00 111793679.90 0.00 1817.7
0.0 49 0 0 0
17:24:01.0 G15 1 22131060.09 0.00 116299505.50 0.00 3394.2
0.0 33 0 0 0
17:24:01.0 G29 1 20729281.64 0.00 108933113.98 0.00 -297.5
0.0 43 0 0 0
17:24:01.0 G30 1 24830319.94 0.00 130484202.02 0.00 1375.8
0.0 47 0 0 0
Parameter : Value
rtklib version : 2.4.2
rtk server thread : 291211008
rtk server state : run
processing cycle (ms) : 10
positioning mode : single
frequencies : L1+L2
accumulated time to run : 00:17:50.9
cpu time for a cycle (ms) : 1
missing obs data count : 0
bytes in input buffer : 0,0
# of input data rover :
obs(1071),nav(7),gnav(0),ion(1),sbs(0),pos(0),dgps(0),ssr(0),err(0)
# of input data base :
obs(0),nav(0),gnav(0),ion(0),sbs(0),pos(0),dgps(0),ssr(0),err(0)
# of input data corr :
# of rtcm messages rover :
# of rtcm messages base :
# of rtcm messages corr :
solution status : -
time of receiver clock rover: 2019/09/28 17:26:13.000000000
time sys offset (glo-gps)(s): 0.000000000
solution interval (s) : 0.000
age of differential (s) : 0.000
ratio for ar validation : 0.000
# of satellites rover : 7
# of satellites base : 0
# of valid satellites : 0
rtkrcv> error
17:28:32.00: point pos error (lack of valid sats ns=4)
17:28:33.00: point pos error (lack of valid sats ns=4)
The only setup I am doing on the oemstar is changing to 57600 baud...
COM COM1 57600 N 8 1 N OFF ON
Then I close the terminal and start rtkrcv with the attached rtkrcv.conf
file...
./rtkrcv -o rtkrcv.conf -t 2
Any suggestions for a newbie?
Jon
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20190928/70772672/attachment.html>
# rtkrcv options (2010/08/12 07:12:16, v.2.4.0)
console-passwd =admin
console-timetype =gpst # (0:gpst,1:utc,2:jst,3:tow)
console-soltype =dms # (0:dms,1:deg,2:xyz,3:enu,4:pyl)
console-solflag =1 # (0:off,1:std+2:age/ratio/ns)
inpstr1-type =serial # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,7:ntripcli,8:ftp,9:http)
inpstr2-type =serial # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,7:ntripcli,8:ftp,9:http)
inpstr3-type =off # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,7:ntripcli,8:ftp,9:http)
inpstr1-path =ttyUSB0:57600:8:n:1:off
inpstr2-path =ttyUSB2:57600:8:n:1:off
inpstr3-path =anonymous:passwd at cddis.gsfc.nasa.gov/gps/products/%W/igu%W%D_%hb.sp3.Z::T=-14400,21600,7200,600
inpstr1-format =oem4 # (0:rtcm2,1:rtcm3,2:oem4,3:oem3,4:ubx,5:ss2,6:hemis,7:skytraq,14:sp3)
inpstr2-format =oem4 # (0:rtcm2,1:rtcm3,2:oem4,3:oem3,4:ubx,5:ss2,6:hemis,7:skytraq,14:sp3)
inpstr3-format =sp3 # (0:rtcm2,1:rtcm3,2:oem4,3:oem3,4:ubx,5:ss2,6:hemis,7:skytraq,14:sp3)
inpstr2-nmeareq =off # (0:off,1:latlon,2:single)
inpstr2-nmealat =0 # (deg)
inpstr2-nmealon =0 # (deg)
outstr1-type =off # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,6:ntripsvr)
outstr2-type =off # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,6:ntripsvr)
outstr1-path =sol1_%Y%m%d%h%M.pos
outstr2-path =sol2_%Y%m%d%h%M.pos
outstr1-format =llh # (0:llh,1:xyz,2:enu,3:nmea)
outstr2-format =nmea # (0:llh,1:xyz,2:enu,3:nmea)
logstr1-type =off # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,6:ntripsvr)
logstr2-type =off # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,6:ntripsvr)
logstr3-type =off # (0:off,1:serial,2:file,3:tcpsvr,4:tcpcli,6:ntripsvr)
logstr1-path =rov_%Y%m%d%h%M.log
logstr2-path =ref_%Y%m%d%h%M.log
logstr3-path =cor_%Y%m%d%h%M.log
misc-svrcycle =10 # (ms)
misc-timeout =30000 # (ms)
misc-reconnect =30000 # (ms)
misc-nmeacycle =5000 # (ms)
misc-buffsize =32768 # (bytes)
misc-navmsgsel =rover # (0:all,1:rover,1:base,2:corr)
misc-startcmd =./rtkstart.sh
misc-stopcmd =./rtkshut.sh
file-cmdfile1 =../../../data/oem4_raw_1hz.cmd
file-cmdfile2 =../../../data/oem4_raw_1hz.cmd
file-cmdfile3 =
pos1-posmode =single # (0:single,1:dgps,2:kinematic,3:static,4:movingbase,5:fixed,6:ppp-kine,7:ppp-static)
pos1-frequency =l1+l2 # (1:l1,2:l1+l2,3:l1+l2+l5)
pos1-soltype =forward # (0:forward,1:backward,2:combined)
pos1-elmask =15 # (deg)
pos1-snrmask =0 # (dBHz)
pos1-dynamics =off # (0:off,1:on)
pos1-tidecorr =off # (0:off,1:on)
pos1-ionoopt =brdc # (0:off,1:brdc,2:sbas,3:dual-freq,4:est-stec)
pos1-tropopt =saas # (0:off,1:saas,2:sbas,3:est-ztd,4:est-ztdgrad)
pos1-sateph =precise # (0:brdc,1:precise,2:brdc+sbas,3:brdc+ssrapc,4:brdc+ssrcom)
pos1-exclsats = # (prn ...)
pos1-navsys =1 # (1:gps+2:sbas+4:glo+8:gal+16:qzs+32:comp)
pos2-armode =off # (0:off,1:continuous,2:instantaneous,3:fix-and-hold)
pos2-gloarmode =off # (0:off,1:on,2:autocal)
pos2-arthres =5
pos2-arlockcnt =0
pos2-arelmask =0 # (deg)
pos2-aroutcnt =5
pos2-arminfix =10
pos2-slipthres =0.05 # (m)
pos2-maxage =30 # (s)
pos2-rejionno =30 # (m)
pos2-niter =1
pos2-baselen =0 # (m)
pos2-basesig =0 # (m)
out-solformat =llh # (0:llh,1:xyz,2:enu,3:nmea)
out-outhead =on # (0:off,1:on)
out-outopt =off # (0:off,1:on)
out-timesys =gpst # (0:gpst,1:utc,2:jst)
out-timeform =tow # (0:tow,1:hms)
out-timendec =3
out-degform =deg # (0:deg,1:dms)
out-fieldsep =
out-height =ellipsoidal # (0:ellipsoidal,1:geodetic)
out-geoid =internal # (0:internal,1:egm96,2:egm08_2.5,3:egm08_1,4:gsi2000)
out-solstatic =all # (0:all,1:single)
out-nmeaintv1 =0 # (s)
out-nmeaintv2 =0 # (s)
out-outstat =off # (0:off,1:state,2:residual)
stats-errratio =100
stats-errphase =0.003 # (m)
stats-errphaseel =0.003 # (m)
stats-errphasebl =0 # (m/10km)
stats-errdoppler =1 # (Hz)
stats-stdbias =30 # (m)
stats-stdiono =0.03 # (m)
stats-stdtrop =0.3 # (m)
stats-prnaccelh =1 # (m/s^2)
stats-prnaccelv =0.1 # (m/s^2)
stats-prnbias =0.0001 # (m)
stats-prniono =0.001 # (m)
stats-prntrop =0.0001 # (m)
stats-clkstab =5e-12 # (s/s)
ant1-postype =llh # (0:llh,1:xyz,2:single,3:posfile,4:rinexhead,5:rtcm)
ant1-pos1 =0 # (deg|m)
ant1-pos2 =0 # (deg|m)
ant1-pos3 =0 # (m|m)
ant1-anttype =
ant1-antdele =0 # (m)
ant1-antdeln =0 # (m)
ant1-antdelu =0 # (m)
ant2-postype =llh # (0:llh,1:xyz,2:single,3:posfile,4:rinexhead,5:rtcm)
ant2-pos1 =0 # (deg|m)
ant2-pos2 =0 # (deg|m)
ant2-pos3 =0 # (m|m)
ant2-anttype =
ant2-antdele =0 # (m)
ant2-antdeln =0 # (m)
ant2-antdelu =0 # (m)
misc-timeinterp =off # (0:off,1:on)
misc-sbasatsel =0 # (0:all)
file-satantfile =../../../data/igs05.atx
file-rcvantfile =../../../data/igs05.atx
file-staposfile =../../../data/station.pos
file-geoidfile =
file-dcbfile =../../../data/P1C1_ALL.DCB
file-tempdir =temp
file-geexefile =
file-solstatfile =
file-tracefile =
More information about the FOSS-GPS
