[FOSS-GPS] Problem Post Processing on RTKPost
Januar Ramadhan januarramadhan1997 at gmail.com
Tue Apr 7 20:47:26 PDT 2020
I have a problem regarding processing gnss data using RTKPOST, when I do
data processing using TOPCON's application, I get coordinate results that
are close to the correct coordinate values, but when using RTKPOST the
coordinates are far from the actual value. Do I have to change the RTKPOST
settings? which part should i change? thank you
Best Regards.
Januar Ramadhan Putra
PT. Luwes Inovasi Mandiri
Website : www.luwesinovasimandiri.com
No. Handphone : 085100222873
Line User Id : januar.rp
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20200408/cecec6fb/attachment.html>
More information about the FOSS-GPS mailing list
