[FOSS-GPS] rtklib not outputting any solution
sam at samthurtle.com.au sam at samthurtle.com.au
Thu Aug 25 01:46:29 PDT 2022
Hello members of the FOSS-GPS mailing list.
My name is Sam. It is nice to e-meet you all, and I hope you can help me
with an rtklib issue I am experiencing.
I have a U-blox NEO-M8P GPS receiver board connected via serial to my
NVIDIA Jetson running Ubuntu 18.04.
I am trying to use rtklib-qt to apply RTK corrections via NTRIP and
output a log file with the corrected solution. When I output the log
file for the solution, it outputs an empty file.
If I output the raw GPS in NMEA, I can see the pre-corrected stream is
output as expected.
If I output the correction stream in NMEA, I can see the corrections are
being output as expected.
It is also worth mentioning that I was not able to get the solution
results panel on the left of the main rtknavi window to display any
data. It just shows "Solution: ----" and lat/long/height 0.
Has anybody experienced this before, and perhaps able to offer any
advice?
I have also tested using rtklib 2.4.3 b34 on a Windows computer and I'm
experiencing the same issue, so I expect it's more than likely a setup
issue rather than a bug.
Please also see below some screenshots which may help in determining my
issue. Thanks in advance.
Input window:
See attached 1_input_window.png.
Rover options:
See attached 2_input_window_rover_options.png.
Correction options (obfuscated for security, duh)
See attached 3_input_window_correction_options.png.
Output streams:
See attached 4_output_streams.png.
(I tried to output the solution as both Lat/Long/Height and NMEA0183).
Log outputs:
See attached 5_log_outputs.png.
Kind regards,
Sam
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20220825/1e194cd8/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20220825/1e194cd8/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20220825/1e194cd8/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20220825/1e194cd8/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20220825/1e194cd8/attachment-0009.png>
More information about the FOSS-GPS mailing list
