[fusion-commits] r1446 - in branches/fusion-1.0: MapGuide lib
widgets widgets/Search
svn_fusion at osgeo.org
Fri Aug 1 15:22:16 EDT 2008
Author: madair
Date: 2008-08-01 15:22:16 -0400 (Fri, 01 Aug 2008)
New Revision: 1446
branches/fusion-1.0/MapGuide/MapGuide.js
branches/fusion-1.0/MapGuide/MapGuideViewerApi.js
branches/fusion-1.0/lib/Map.js
branches/fusion-1.0/widgets/Search/Search.templ
branches/fusion-1.0/widgets/ViewOptions.js
closes #89: make calls to setSelection consistent; patch applied to 1.0 branch;
also adds missing method for ViewOptions widget
Modified: branches/fusion-1.0/MapGuide/MapGuide.js
--- branches/fusion-1.0/MapGuide/MapGuide.js 2008-08-01 19:21:15 UTC (rev 1445)
+++ branches/fusion-1.0/MapGuide/MapGuide.js 2008-08-01 19:22:16 UTC (rev 1446)
@@ -628,7 +628,7 @@
var params = {
'mapname': this.getMapName(),
'session': this.getSessionID(),
- 'selection': encodeURIComponent(selText),
+ 'selection': selText,
'seq': Math.random()
var options = {onSuccess: OpenLayers.Function.bind(this.processQueryResults, this, zoomTo),
Modified: branches/fusion-1.0/MapGuide/MapGuideViewerApi.js
--- branches/fusion-1.0/MapGuide/MapGuideViewerApi.js 2008-08-01 19:21:15 UTC (rev 1445)
+++ branches/fusion-1.0/MapGuide/MapGuideViewerApi.js 2008-08-01 19:22:16 UTC (rev 1446)
@@ -40,7 +40,7 @@
var Fusion = window.top.Fusion;
var mapWidget = Fusion.getWidgetById(mapWidgetId);
if (mapWidget && mapWidget.isMapLoaded()) {
- mapWidget.setSelection(selectionXml, true, true);
+ mapWidget.setSelection(selectionXml, true);
Modified: branches/fusion-1.0/lib/Map.js
--- branches/fusion-1.0/lib/Map.js 2008-08-01 19:21:15 UTC (rev 1445)
+++ branches/fusion-1.0/lib/Map.js 2008-08-01 19:22:16 UTC (rev 1446)
@@ -389,13 +389,13 @@
- * Function: setSelectionXML
+ * Function: setSelection
* sets a Selection XML back to the server
- setSelection: function(selText, requery, zoomTo) {
+ setSelection: function(selText, zoomTo) {
for (var i=0; i<this.aMaps.length; i++ ) {
- this.aMaps[i].setSelection(selText, requery, zoomTo);
+ this.aMaps[i].setSelection(selText, zoomTo);
Modified: branches/fusion-1.0/widgets/Search/Search.templ
--- branches/fusion-1.0/widgets/Search/Search.templ 2008-08-01 19:21:15 UTC (rev 1445)
+++ branches/fusion-1.0/widgets/Search/Search.templ 2008-08-01 19:22:16 UTC (rev 1446)
@@ -83,7 +83,7 @@
function CellClicked(sel)
var map = GetParent().Fusion.getMapByName(mapName);
- map.setSelection(sel, false, true);
+ map.setSelection(sel, true);
function highlightRow(index, mode)
Modified: branches/fusion-1.0/widgets/ViewOptions.js
--- branches/fusion-1.0/widgets/ViewOptions.js 2008-08-01 19:21:15 UTC (rev 1445)
+++ branches/fusion-1.0/widgets/ViewOptions.js 2008-08-01 19:22:16 UTC (rev 1446)
@@ -64,6 +64,10 @@
this.oMenu.show(e);
+ setViewOptions: function(units) {
+ this.getMap().setViewOptions(units);
setMapUnits: function() {
var units = this.displayUnits ? this.displayUnits : this.getMap().getUnits();
More information about the fusion-commits
