[fusion-commits] r1459 - in trunk: MapGuide MapGuide/php widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Aug 13 13:34:30 EDT 2008
Author: madair
Date: 2008-08-13 13:34:30 -0400 (Wed, 13 Aug 2008)
New Revision: 1459
   trunk/MapGuide/MapGuide.js
   trunk/MapGuide/php/Buffer.php
   trunk/widgets/Buffer.js
closes #104: add a noCache flag to layers to prevent caching of legend icons; remove debugging output from Buffer.php
Modified: trunk/MapGuide/MapGuide.js
--- trunk/MapGuide/MapGuide.js	2008-08-12 20:17:15 UTC (rev 1458)
+++ trunk/MapGuide/MapGuide.js	2008-08-13 17:34:30 UTC (rev 1459)
@@ -366,6 +366,7 @@
               for (var j=0; j<this.oldLayers.length; ++j){
                 if (this.oldLayers[j].uniqueId == newLayer.uniqueId) {
                   newLayer.selectedFeatureCount = this.oldLayers[j].selectedFeatureCount;
+                  newLayer.noCache = this.oldLayers[j].noCache;
                   break;
@@ -1203,6 +1204,15 @@
     getLegendImageURL: function(fScale, layer) {
         var url = Fusion.getConfigurationItem('mapguide', 'mapAgentUrl');
-        return url + "OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID() + "&VERSION=1.0.0&SCALE=" + fScale + "&LAYERDEFINITION=" + encodeURIComponent(layer.resourceId) + "&THEMECATEGORY=" + this.categoryIndex + "&TYPE=" + this.geometryType + "&CLIENTAGENT=" + encodeURIComponent(this.clientAgent);
+        url += "OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID();
+        url += "&VERSION=1.0.0&SCALE=" + fScale;
+        url += "&LAYERDEFINITION=" + encodeURIComponent(layer.resourceId);
+        url += "&THEMECATEGORY=" + this.categoryIndex;
+        url += "&TYPE=" + this.geometryType;
+        url += "&CLIENTAGENT=" + encodeURIComponent(this.clientAgent);
+        if (layer.noCache) {
+          url += "&TS=" + (new Date()).getTime();
+        return url;
Modified: trunk/MapGuide/php/Buffer.php
--- trunk/MapGuide/php/Buffer.php	2008-08-12 20:17:15 UTC (rev 1458)
+++ trunk/MapGuide/php/Buffer.php	2008-08-13 17:34:30 UTC (rev 1459)
@@ -216,7 +216,7 @@
             $wktReaderWriter = new MgWktReaderWriter();
             $agfTextPoint = $wktReaderWriter->Write($oGeom);
-            echo "<!-- wkt: ".$agfTextPoint." -->\n";
+            //echo "<!-- wkt: ".$agfTextPoint." -->\n";
             if (!$merge) {
                 /* use measure to accomodate differences in SRS */
                 $oNewGeom = $oGeom->Buffer($dist, $measure);
Modified: trunk/widgets/Buffer.js
--- trunk/widgets/Buffer.js	2008-08-12 20:17:15 UTC (rev 1458)
+++ trunk/widgets/Buffer.js	2008-08-13 17:34:30 UTC (rev 1459)
@@ -169,12 +169,10 @@
     execute: function() {
-        var layer = '&layer=';
         if (this.layerNameInput) {
-            layer += this.getValue(this.layerNameInput);
-        } else {
-            layer += this.layerName;
+            this.layerName = this.getValue(this.layerNameInput);
+        var layer = '&layer=' + this.layerName;
         var d;
         if (this.bufferDistanceInput) {
@@ -222,6 +220,10 @@
     bufferCreated: function() {
         var aMaps = this.getMap().getAllMaps();
+        var layer = aMaps[0].getLayerByName(this.layerName);
+        if (layer) {
+          layer.noCache = true;
         aMaps[0].reloadMap();
         aMaps[0].drawMap();
More information about the fusion-commits mailing list
