[fusion-commits] r1471 - trunk
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Aug 22 15:19:57 EDT 2008
Author: madair
Date: 2008-08-22 15:19:57 -0400 (Fri, 22 Aug 2008)
New Revision: 1471
   trunk/build.xml
   trunk/fusion.cfg
re #109: set version in build.xml; revert change to OL fusion build config (Request.js is only in trunk/2.7)
Modified: trunk/build.xml
--- trunk/build.xml	2008-08-22 19:18:37 UTC (rev 1470)
+++ trunk/build.xml	2008-08-22 19:19:57 UTC (rev 1471)
@@ -74,7 +74,7 @@
   <property environment="env"/>
   <property name="app.name" value="fusion"/>
   <property name="app.path" value="/${app.name}"/>
-  <property name="app.version" value="1.0-beta6"/>
+  <property name="app.version" value="1.1.x"/>
   <property name="build.home" value="${basedir}/build"/>
   <property name="deploy.home" value="${env.HTDOCS}/${app.name}"/>
   <property name="dist.home" value="${basedir}/dist"/>
Modified: trunk/fusion.cfg
--- trunk/fusion.cfg	2008-08-22 19:18:37 UTC (rev 1470)
+++ trunk/fusion.cfg	2008-08-22 19:19:57 UTC (rev 1471)
@@ -8,7 +8,6 @@
 OpenLayers/BaseTypes/Class.js
 OpenLayers/Util.js
 OpenLayers/Ajax.js
-OpenLayers/Request.js
 OpenLayers/Console.js
 OpenLayers/BaseTypes/Size.js
 OpenLayers/BaseTypes/Bounds.js
More information about the fusion-commits mailing list
