[fusion-commits] r1725 - in branches/fusion2-mg21: . layers/MapGuide lib widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Dec 18 17:46:17 EST 2008
Author: chrisclaydon
Date: 2008-12-18 17:46:17 -0500 (Thu, 18 Dec 2008)
New Revision: 1725
   branches/fusion2-mg21/build.xml
   branches/fusion2-mg21/layers/MapGuide/MapGuideViewerApi.js
   branches/fusion2-mg21/lib/fusion.js
   branches/fusion2-mg21/widgets/Legend.js
   branches/fusion2-mg21/widgets/Maptip.js
Ref #196 - Apply maptip fixes to branch
Modified: branches/fusion2-mg21/build.xml
--- branches/fusion2-mg21/build.xml	2008-12-18 20:58:20 UTC (rev 1724)
+++ branches/fusion2-mg21/build.xml	2008-12-18 22:46:17 UTC (rev 1725)
@@ -17,7 +17,7 @@
      from which Ant executes the requested task.  This is normally
      set to the current working directory.
-  <project basedir="." default="compress" name="fusion">
+  <project basedir="." default="deploy" name="fusion">
 <!-- ===================== Property Definitions =========================== -->
@@ -74,9 +74,9 @@
   <property environment="env"/>
   <property name="app.name" value="fusion"/>
   <property name="app.path" value="/${app.name}"/>
-  <property name="app.version" value="2.0.x"/>
+  <property name="app.version" value="1.1.x"/>
   <property name="build.home" value="${basedir}/build"/>
-  <property name="deploy.home" value="."/>
+  <property name="deploy.home" value="${basedir}/../${app.name}"/>
   <property name="dist.home" value="${basedir}/dist"/>
   <property name="docs.home" value="${build.home}/docs"/>
Modified: branches/fusion2-mg21/layers/MapGuide/MapGuideViewerApi.js
--- branches/fusion2-mg21/layers/MapGuide/MapGuideViewerApi.js	2008-12-18 20:58:20 UTC (rev 1724)
+++ branches/fusion2-mg21/layers/MapGuide/MapGuideViewerApi.js	2008-12-18 22:46:17 UTC (rev 1725)
@@ -60,7 +60,13 @@
       var digitizer = new Fusion.Tool.Canvas.Point(mapWidget);
       digitizer.mouseUp = PointHandlers.prototype.mouseUp;
       Object.inheritFrom(digitizer, Fusion.Tool.Canvas.prototype, []);
-      digitizer.handler = handler;
+      digitizer.initializeCanvas();
+      var activeWidget = mapWidget.buttonSet.activeButton;
+      mapWidget.buttonSet.setActiveButton(null);
+      digitizer.handler = function() {
+          handler.apply(null, arguments);
+          activeWidget.setActive(true);
       digitizer.activateCanvas();
       //add a listener to update the position of the features
@@ -83,7 +89,13 @@
       digitizer.mouseDown = LineHandlers.prototype.mouseDown;
       digitizer.mouseMove = LineHandlers.prototype.mouseMove;
@@ -107,7 +119,13 @@
       digitizer.mouseMove = MultiPointHandlers.prototype.mouseMove;
       digitizer.dblClick = MultiPointHandlers.prototype.dblClick;
@@ -130,7 +148,13 @@
       digitizer.mouseDown = RectangleHandlers.prototype.mouseDown;
       digitizer.mouseMove = RectangleHandlers.prototype.mouseMove;
@@ -154,7 +178,13 @@
Modified: branches/fusion2-mg21/lib/fusion.js
--- branches/fusion2-mg21/lib/fusion.js	2008-12-18 20:58:20 UTC (rev 1724)
+++ branches/fusion2-mg21/lib/fusion.js	2008-12-18 22:46:17 UTC (rev 1725)
@@ -49,7 +49,9 @@
             destination[property] = parent[property];
-    parent.initialize.apply(destination, args);
+    if (parent.initialize) {
+        parent.initialize.apply(destination, args);
 (function() {
Modified: branches/fusion2-mg21/widgets/Legend.js
--- branches/fusion2-mg21/widgets/Legend.js	2008-12-18 20:58:20 UTC (rev 1724)
+++ branches/fusion2-mg21/widgets/Legend.js	2008-12-18 22:46:17 UTC (rev 1725)
@@ -332,6 +332,16 @@
             if (item instanceof Jx.TreeFolder) {
                 this.recurseTree(op, item);
                 item[op]();
+                if (item.domObj) {
+                    var p = $(item.domObj).getPrevious();
+                    if (p) {
+                        item.domObj.dispose();
+                        $(item.domObj).inject(p, 'before');
+                    } else {
+                        p = $(item.domObj).getParent();
+                        $(item.domObj).inject(p, 'top');
Modified: branches/fusion2-mg21/widgets/Maptip.js
--- branches/fusion2-mg21/widgets/Maptip.js	2008-12-18 20:58:20 UTC (rev 1724)
+++ branches/fusion2-mg21/widgets/Maptip.js	2008-12-18 22:46:17 UTC (rev 1725)
@@ -56,7 +56,7 @@
     aLayers: null,
     bOverTip: false,
     sWinFeatures: 'menubar=no,location=no,resizable=no,status=no',
-    offset: new OpenLayers.Pixel(2,2),
+    offset: new OpenLayers.Pixel(2,20),
     initializeWidget: function(widgetTag) {
         var json = widgetTag.extension;
@@ -100,6 +100,8 @@
         document.getElementsByTagName('BODY')[0].appendChild(this.domObj);
         this.getMap().observeEvent('mousemove', OpenLayers.Function.bind(this.mouseMove, this));
+        this.getMap().observeEvent('mousedown', OpenLayers.Function.bind(this.mouseDown, this));
+        this.getMap().observeEvent('mouseup', OpenLayers.Function.bind(this.mouseUp, this));
         this.getMap().observeEvent('mouseout', OpenLayers.Function.bind(this.mouseOut, this));
@@ -117,7 +119,7 @@
     mouseMove: function(e) {
       //console.log('map tip mouseMove');
-        if (this.bOverTip) {
+        if (this.bOverTip || this.mouseIsDown) {
             return;
@@ -136,6 +138,15 @@
         //Event.stop(e);
+    mouseDown: function() {
+        this.mouseIsDown = true;
+        this._hide();
+    mouseUp: function() {
+        this.mouseIsDown = false;
     showMaptip: function(r) {
       //console.log('showMaptip');
         var map = this.getMap();
@@ -185,6 +196,10 @@
     _display: function(tooltip) {
+        if (this.mouseIsDown) {
+            return;
       //console.log('maptip _display');
             this.domObj.innerHTML = '&nbsp;';
             var contentDiv = document.createElement('div');
More information about the fusion-commits mailing list
