[fusion-commits] r1443 - in trunk: MapGuide/php widgets
    svn_fusion at osgeo.org
    Fri Jul 25 12:07:30 EDT 2008
Author: zjames
Date: 2008-07-25 12:07:30 -0400 (Fri, 25 Jul 2008)
New Revision: 1443
   trunk/MapGuide/php/SaveMap.php
   trunk/widgets/SaveMap.js
closes #91 - savemap dwf scales ignored. Also simplifies SaveMap.php DWF handling.
Modified: trunk/MapGuide/php/SaveMap.php
--- trunk/MapGuide/php/SaveMap.php	2008-07-22 15:00:30 UTC (rev 1442)
+++ trunk/MapGuide/php/SaveMap.php	2008-07-25 16:07:30 UTC (rev 1443)
@@ -27,7 +27,6 @@
  * Purpose: get map initial information
 include('Common.php');
 $format     = isset($_REQUEST['format']) ? $_REQUEST['format'] : 'png';
 $layout     = isset($_REQUEST['layout']) ? $_REQUEST['layout'] : null;
@@ -37,7 +36,6 @@
 $pageHeight = isset($_REQUEST['pageheight']) ? $_REQUEST['pageheight'] : 11;
 $pageWidth  = isset($_REQUEST['pagewidth']) ? $_REQUEST['pagewidth'] : 8.5;
 $aMargins = isset($_REQUEST['margins']) ? explode(',',$_REQUEST['margins']) : array(0,0,0,0);
 try
     $mappingService = $siteConnection->CreateService(MgServiceType::MappingService);
@@ -48,13 +46,12 @@
     $selection = new MgSelection($map);
     $selection->Open($resourceService, $mapName);
-    //compute center
-    $extent = $map->GetMapExtent();
-    $centerX = $extent->GetLowerLeftCoordinate()->GetX() + ($extent->GetWidth())/2;
-    $centerY = $extent->GetLowerLeftCoordinate()->GetY() + ($extent->GetHeight())/2;
-    $geomFactory = new MgGeometryFactory();
-    $center = $geomFactory->CreateCoordinateXY($centerX, $centerY);
+    //get current center as a coordinate
+    $center = $map->GetViewCenter()->GetCoordinate();
+    //plot with the passed scale, if provided
+    $scale = isset($_REQUEST['scale']) ? $_REQUEST['scale'] : $map->GetViewScale();
     if ($format == 'DWF') {
         $oLayout = null;
         if ($layout) {
@@ -71,53 +68,15 @@
         $dwfVersion = new MgDwfVersion('6.01','1.2');
-        if ($scale) {
-            //plot with the passed scale
-            $coordSysFactory = new MgCoordinateSystemFactory();
-            $coordSystem = $coordSysFactory->Create($map->GetMapSRS());
-            $metersPerUnit = $coordSystem->ConvertCoordinateSystemUnitsToMeters(1.0);
-            $metersPerPixel = 1.0/(100.0 / 2.54 * $map->GetDisplayDpi());
-            $height = $map->GetDisplayHeight();
-            $width = $map->GetDisplayWidth();
-            $mapWidth = $scale * $width * $metersPerPixel/$metersPerUnit;
-            $mapHeight = $scale * $height * $metersPerPixel/$metersPerUnit;
-            $extent = new MgEnvelope(
-                                      $center->GetX() - 0.5*$mapWidth,
-                                      $center->GetY() - 0.5*$mapHeight,
-                                      $center->GetX() + 0.5*$mapWidth,
-                                      $center->GetY() + 0.5*$mapHeight);
-            //this is broken because the swig api has an error
-            //$center = $map->GetViewCenter();
-            // echo $oPlotSpec; exit;
-            //echo $map->GetName()." ".$center->GetX().", ".
-            //                        $center->GetY().", ".
-            //                        $scale."  paper height: ".
-            //$oPlotSpec->GetPaperHeight().", layout: ".$oLayout->GetTitle().", dwfVersion ".$dwfVersion->GetFileVersion()."\n";
-            // $oImg = $mappingService->GeneratePlot($map,
-            //                                   $center,
-            //                                   $scale,
-            //                                   $oPlotSpec,
-            //                                   $oLayout,
-            //                                   $dwfVersion);
-            $oImg = $mappingService->GeneratePlot($map, $extent, true,
-                                              $oPlotSpec,
-                                              $oLayout,
-                                              $dwfVersion);
-        } else {
-            //use current extents for plot
-            $oImg = $mappingService->GeneratePlot($map, $extent, false,
-                                              $oPlotSpec,
-                                              $oLayout,
-                                              $dwfVersion);
+        $oImg = $mappingService->GeneratePlot($map,
+                                          $center,
+                                          $scale,
+                                          $oPlotSpec,
+                                          $oLayout,
+                                          $dwfVersion);
     } else {
         //render as an image
         if (isset($imgHeight) && isset($imgWidth)) {
-            $scale = $map->GetViewScale();
             $oImg = $renderingService->RenderMap($map, $selection,
                                                  $center, $scale,
                                                  $imgWidth, $imgHeight,
Modified: trunk/widgets/SaveMap.js
--- trunk/widgets/SaveMap.js	2008-07-22 15:00:30 UTC (rev 1442)
+++ trunk/widgets/SaveMap.js	2008-07-25 16:07:30 UTC (rev 1443)
@@ -80,10 +80,11 @@
                 if (layout.Scale) {
                     //create entries for weblayout specified scales
                     menuItem = new Jx.SubMenu(opt);
+                    data.scales = [];
                     for (var j=0; j < layout.Scale.length; j++) {
-                        data.scale = layout.Scale[j];
-                        var scaleAction = new Jx.Action(this.setLayout.bind(this, data));
-                        var subMenuItem = new Jx.MenuItem(scaleAction,{label:data.scale});
+                        data.scales.push(layout.Scale[j]);
+                        var scaleAction = new Jx.Action(this.setLayout.bind(this, data, j));
+                        var subMenuItem = new Jx.MenuItem(scaleAction,{label:layout.Scale[j]});
                         menuItem.add(subMenuItem);
                     //add an entry for current scale
@@ -116,11 +117,17 @@
     setLayout: function(data) {
-        this.printScale = data.scale;
         this.printLayout = data.rid;
         this.pageHeight = data.pageHeight;
         this.pageWidth = data.pageWidth;
         this.pageMargins = data.margins;
+        //when the selected item has a scale, the index into the scales array
+        //is passed, otherwise value is reset and current scale is used.
+        if (arguments.length == 3){
+            this.printScale = parseFloat(data.scales[arguments[1]]);
+        } else {
+            this.printScale = null;
         this.activateTool();
@@ -171,10 +178,10 @@
         var m = this.getMap().aMaps[0];
         if(navigator.appVersion.match(/\bMSIE\b/)) {
-            var url = Fusion.fusionURL + '/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMapFrame." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format + szLayout + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
+            var url = Fusion.fusionURL + '/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMapFrame." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format + szLayout + szScale + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
             w = open(url, "Save", 'menubar=no,height=200,width=300');
         } else {
-            var s = Fusion.fusionURL + '/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMap." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format + szLayout + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
+            var s = Fusion.fusionURL + '/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMap." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format + szLayout + szScale + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
             this.iframe.src = s;
More information about the fusion-commits
