[fusion-commits] r1426 - trunk/MapServer/php
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Jun 26 11:58:25 EDT 2008
Author: pagameba
Date: 2008-06-26 11:58:25 -0400 (Thu, 26 Jun 2008)
New Revision: 1426
   trunk/MapServer/php/SetLayers.php
fix problem deleting layers, need to use constant MS_DELETE instead of string "MS_DELETE" for layer status.
Modified: trunk/MapServer/php/SetLayers.php
--- trunk/MapServer/php/SetLayers.php	2008-06-25 21:09:33 UTC (rev 1425)
+++ trunk/MapServer/php/SetLayers.php	2008-06-26 15:58:25 UTC (rev 1426)
@@ -1,76 +1,80 @@
-<?php
- * SetLayers
- * $Id$
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
- * Purpose: Set the layers that are in the current Map in the session
-/* set up the session */
-include ("Common.php");
-include ("Utilities.php");
-if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
-    $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
-/* the name of the layer in the map to query */
-if ($_REQUEST['layerindex'] != '') {
-	$layers = explode(',',$_REQUEST['layerindex']);
-} else {
-	$layers = array();
-$currentLayers = $oMap->getlayersdrawingorder();
-if (count($currentLayers) != count($layers) ) {
-	for ($i=0; $i<count($layers); $i++) {
-		if ($i != $layers[$i]) {
-			$layer = $oMap->getLayer($i);
-			$tmp = $layer->set('status', 'MS_DELETE');
-			if ($tmp >= 0) {
-				$res = true;
-			} else {
-				$res = false;
-			break;
-		$res = false;
-} else {
-	$res = $oMap->setlayersdrawingorder($layers);
-header('Content-type: text/x-json');
-header('X-JSON: true');
-if ($res) {
-	$oMap->save($_SESSION['maps'][$mapName]);
-	$currentLayers = $oMap->getlayersdrawingorder();
-    echo "{success: true, layerindex: [".implode(",",$currentLayers)."]}";
-} else {
-    echo "{success: false, layerindex: [".$_REQUEST['layerindex']."]}";
+<?php
+ * SetLayers
+ * $Id$
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Purpose: Set the layers that are in the current Map in the session
+/* set up the session */
+include ("Common.php");
+include ("Utilities.php");
+header('Content-type: text/x-json');
+header('X-JSON: true');
+if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
+    $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
+/* the name of the layer in the map to query */
+if ($_REQUEST['layerindex'] != '') {
+	$layers = explode(',',$_REQUEST['layerindex']);
+} else {
+	$layers = array();
+$currentLayers = $oMap->getlayersdrawingorder();
+if (count($currentLayers) != count($layers) ) {
+  echo "/* removing layers ";
+	for ($i=0; $i<count($layers); $i++) {
+		if ($i != $layers[$i]) {
+		  echo $i." ";
+			$layer = $oMap->getLayer($i);
+			$tmp = $layer->set('status', MS_DELETE);
+			if ($tmp >= 0) {
+				$res = true;
+			} else {
+				$res = false;
+			break;
+		$res = false;
+		echo "*/";
+} else {
+  echo "/* reordering layers */";
+	$res = $oMap->setlayersdrawingorder($layers);
+if ($res) {
+	$oMap->save($_SESSION['maps'][$mapName]);
+	$currentLayers = $oMap->getlayersdrawingorder();
+    echo "{success: true, layerindex: [".implode(",",$currentLayers)."]}";
+} else {
+    echo "{success: false, layerindex: [".$_REQUEST['layerindex']."]}";
More information about the fusion-commits mailing list
