[fusion-commits] r1340 - in trunk/MapServer: . php
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Mar 26 11:12:59 EDT 2008
Author: wbronsema
Date: 2008-03-26 11:12:59 -0400 (Wed, 26 Mar 2008)
New Revision: 1340
   trunk/MapServer/MapServer.js
   trunk/MapServer/php/LoadMap.php
Fixes #38 - Updated to allow map and layer level metadata to be accessible via the javascript map and layer objects
Modified: trunk/MapServer/MapServer.js
--- trunk/MapServer/MapServer.js	2008-03-25 19:47:19 UTC (rev 1339)
+++ trunk/MapServer/MapServer.js	2008-03-26 15:12:59 UTC (rev 1340)
@@ -48,6 +48,8 @@
     bMapLoaded : false,
     bIsMapWidgetLayer : true,  //Setthis to false for overview map layers
     bLayersReversed: true,     //MS returns layers bottom-most layer first, we treat layer order in reverse sense
+    mapMetadataKeys: null,
+    layerMetadataKeys: null,
     //the map file
     sMapFile: null,
@@ -90,6 +92,9 @@
         this.sMapFile = extension.MapFile ? extension.MapFile[0] : '';
+        this.mapMetadataKeys = extension.MapMetadata ? extension.MapMetadata[0] : null;
+        this.layerMetadataKeys = extension.LayerMetadata ? extension.LayerMetadata[0] : null;
         this.bSingleTile = mapTag.singleTile;// this is set by the AppDef.Map object
         this.keepAliveInterval = parseInt(extension.KeepAliveInterval ? extension.KeepAliveInterval[0] : 300);
@@ -191,7 +196,15 @@
         var sessionid = this.getSessionID();
-        var params = 'mapfile='+mapfile+"&session="+sessionid;
+        var metadata = '';
+        if (this.mapMetadataKeys) {
+            metadata += '&map_metadata='+this.mapMetadataKeys;
+        if (this.layerMetadataKeys) {
+            metadata += '&layer_metadata='+this.layerMetadataKeys;
+        var params = 'mapfile='+mapfile+"&session="+sessionid+metadata;
         var options = {onSuccess: this.mapLoaded.bind(this),
                                      parameters: params};
         Fusion.ajaxRequest(loadmapScript, options);
@@ -208,6 +221,7 @@
             this._fMetersperunit = o.metersPerUnit;
             this.mapWidget._fMetersperunit = this._fMetersperunit;
             this._sImageType = o.imagetype;
+            this.metadata = o.metadata;
             this._oMaxExtent = OpenLayers.Bounds.fromArray(o.extent);
@@ -316,8 +330,15 @@
         var loadmapScript = this.arch + '/' + sl  + '/LoadMap.' + sl;
-        var params = 'mapname='+this._sMapname+"&session="+sessionid;
+        var params = 'mapname='+this._sMapname+"&session="+sessionid+metadata;
         var options = {onSuccess: this.mapReloaded.bind(this),
@@ -327,6 +348,10 @@
         if (json) {
             var o;
             eval('o='+r.responseText);
+            //can metadata change?
+            //this.metadata = o.metadata;
             this.parseMapLayersAndGroups(o);
             this.aVisibleLayers = [];
             for (var i=0; i<this.aLayers.length; i++) {
@@ -695,6 +720,14 @@
     getLayerInfoUrl: function(layerName) {
       return null;
+  getMetadata: function(key) {
+      if (typeof this.metadata[key] != 'undefined') {
+          return this.metadata[key];
+      } else {
+          return '';
@@ -781,6 +814,7 @@
         this.actuallyVisible = o.actuallyVisible;
         this.editable = o.editable;
         this.parentGroup = o.parentGroup;
         this.scaleRanges = [];
     		this.minScale = 1.0e10;
     		this.maxScale = 0;
@@ -829,6 +863,14 @@
     isVisible: function() {
         var bParentVisible = this.parentGroup ? this.parentGroup.isVisible() : true;
         return this.visible && bParentVisible;
+        } else {
+            return '';
Modified: trunk/MapServer/php/LoadMap.php
--- trunk/MapServer/php/LoadMap.php	2008-03-25 19:47:19 UTC (rev 1339)
+++ trunk/MapServer/php/LoadMap.php	2008-03-26 15:12:59 UTC (rev 1340)
@@ -41,16 +41,16 @@
 /* could potentially make this optional */
 $moveToSession = true;
    TODO make it possible to specify only a relative path
    in the WebLayout and have this code know where to
    look for it on the server somehow
 /* only do something if a mapfile was requested */
 if (isset($_REQUEST['mapfile'])) {
     $oMap = ms_newMapObj($_REQUEST['mapfile']);
     /* optionally move the mapfile to the session */
     if ($moveToSession) {
         //path to map file in the session is used by the client
@@ -70,7 +70,7 @@
             $oMap->setFontSet(realpath($fontSet));
         /* need to modify all image symbols reference in the map file
-         eg STYLE
+         eg STYLE
              SYMBOL "../etc/markers/target-7.gif" : this is relative to the map file
         for ($i=0; $i<$oMap->numlayers; $i++)
@@ -115,6 +115,14 @@
     $mapObj->sessionId = $sessionID;
     $mapObj->mapId = $mapId;
+    $mapObj->metadata = NULL;
+    if (isset($_REQUEST['map_metadata'])) {
+        $mapMetadataKeys = explode(',',$_REQUEST['map_metadata']);
+        foreach($mapMetadataKeys as $key) {
+            $mapObj->metadata->$key = $oMap->getMetadata($key);
     $mapObj->metersPerUnit = GetMetersPerUnit($oMap->units);
     $mapObj->dpi = $oMap->resolution;
@@ -126,7 +134,7 @@
     if (!isset($_SESSION['maps'][$mapObj->mapName])) {
         $_SESSION['maps'][$mapObj->mapName] = $mapId;
-    $mapObj->extent = array( $oMap->extent->minx, $oMap->extent->miny,
+    $mapObj->extent = array( $oMap->extent->minx, $oMap->extent->miny,
                              $oMap->extent->maxx, $oMap->extent->maxy );
     $minScale = $oMap->web->minscale == -1 ? MIN_SCALE : $oMap->web->minscale;
     $maxScale = $oMap->web->maxscale == -1 ? MAX_SCALE : $oMap->web->maxscale;
@@ -138,6 +146,15 @@
          $layer=$oMap->GetLayer($i);
          $layerObj = NULL;
+         $layerObj->metadata = NULL;
+         if (isset($_REQUEST['layer_metadata'])) {
+             $layerMetadataKeys = explode(',',$_REQUEST['layer_metadata']);
+             foreach($layerMetadataKeys as $key) {
+                 $layerObj->metadata->$key = $layer->getMetadata($key);
          $layerObj->propertyMappings = '';
          $layerObj->uniqueId = $i;
          $layerObj->layerName = $layer->name;
@@ -159,42 +176,42 @@
                 $type = 0;
          $layerObj->layerTypes = array($type);
          $displayInLegend = strtolower($layer->getMetaData('displayInLegend'));
          $layerObj->displayInLegend = $displayInLegend == 'false' ? false : true;
          $expandInLegend = strtolower($layer->getMetaData('expandInLegend'));
          $layerObj->expandInLegend = $expandInLegend == 'false' ? false : true;
          $layerObj->resourceId = $layer->name;
          $layerObj->parentGroup = $layer->group;
          $legendLabel = $layer->getMetaData('legendLabel');
          if ($legendLabel == '') {
              $legendLabel = $layer->name;
          $layerObj->legendLabel = $legendLabel;
          $selectable = strtolower($layer->getMetaData('selectable'));
          $layerObj->selectable = $selectable == 'true' ? true : false;
          $layerObj->visible = ($layer->status == MS_ON || $layer->status == MS_DEFAULT);
          $layerObj->actuallyVisible = true;
          $editable = strtolower($layer->getMetaData('editable'));
          $layerObj->editable = $editable == 'true' ? true : false;
-         /* process the classes.  The legend expects things
+         /* process the classes.  The legend expects things
           * organized by scale range so we have to first
           * find all the scale breaks, then create ranges
           * for each scale break pair, then slot the classes
           * into the scale ranges that they apply to.
          $aScaleRanges = array();
          //create a default scale range for the layer as a whole
          $layerMin = $layer->minscale == -1 ? $minScale : $layer->minscale;
          $layerMax = $layer->maxscale == -1 ? $maxScale : $layer->maxscale;
-         //find all the unique scale breaks in this layer
+         //find all the unique scale breaks in this layer
          $aScaleBreaks = array($layerMin, $layerMax);
          for ($j=0; $j<$layer->numclasses; $j++) {
              $oClass = $layer->getClass($j);
@@ -209,7 +226,7 @@
          //sort them
          sort($aScaleBreaks);
          //create scale ranges for each pair of breaks
          for ($j=0; $j<count($aScaleBreaks)-1; $j++) {
              $scaleRange = NULL;
@@ -218,7 +235,7 @@
              $scaleRange->styles = array();
              array_push($aScaleRanges, $scaleRange);
          //create classes and slot them into the scale breaks
@@ -239,7 +256,7 @@
          $layerObj->scaleRanges = $aScaleRanges;
          array_push($mapObj->layers, $layerObj);
     $mapObj->groups = array();
     $aGroups = $oMap->getAllGroupNames();
     foreach($aGroups as $groupName) {
@@ -268,7 +285,7 @@
     $b = $layer->getMetaData('groupVisible');
     $group->visible = ($b == 'false') ? false : true;
     $group->actuallyVisible = $layer->isVisible();
     return $group;
More information about the fusion-commits mailing list
